Home > Message Board > Car Audio > Amplifiers > Archive through December 11, 2003 > Amp remote wire
Author Thread: Amp remote wire
DMG
I have a 3.2 CL with the stock head unit that I dont want to get rid of because of the in dash 6 disc changer, as well there is no antenna in this car. What should I hook the remote wire up to???
Adam
you can use ignition/accessory wire. You can get it under the dash or behind the radio, and if you have a factory amplifier you can get it there.
Home > Message Board > Car Audio > Amplifiers > Archive through December 11, 2003 > Amp remote wire [ « Previous ] [ Next » ]
