Thread: Audiobahn |
New member Username: Bhs07
Louisville,
Ky
Post Number: 8 Registered: Jul-06
| Posted on Friday, August 04, 2006 - 11:57 am: |
i am looking at audiobahn amps for my 12' kicker L7 @ 4ohms DVC and there to models one is a old one and a new one which one is better anyone own any of these and what are ure experiecen with them audiobahn a8000v http://sonicelectronix.com/item_6986.html and audiobahn a8000t http://www.cardomain.com/item/ABNA8000T i am not gettin them yet i jsut wana know which one is better ill find the cheapest price from them later tho so let me know which amp is better for my kicker thanks |
Bronze Member Username: Poremski1628
Post Number: 50 Registered: Jun-06
| Posted on Friday, August 04, 2006 - 12:44 pm: |
the A8000t is the older one i have an A8000V and i haven't had any problems with it |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1644 Registered: Dec-05
| Posted on Friday, August 04, 2006 - 01:07 pm: |
bro! if you have the dual 4 ohm version don't get that amp, get the a8002T or V |
Silver Member Username: Crayola0
Wisconsin
Post Number: 396 Registered: Jun-06
| Posted on Friday, August 04, 2006 - 01:49 pm: |
y not, doesnt dual 4 ohm can wire down to 2 ohms? |
Silver Member Username: Adddisorder
West palm,
Florida
Post Number: 539 Registered: Jan-06
| Posted on Friday, August 04, 2006 - 03:25 pm: |
not if you get 2 dual 4 you can only wire them to 1 and 4 |
Gold Member Username: Tjmutlow
Post Number: 2659 Registered: Sep-05
| Posted on Friday, August 04, 2006 - 04:22 pm: |
only 1 sub, it is only going to wire down to 2 ohm or 8ohms. the 8000 series is what you need for just the one sub.... |
Louisville,
Ky
Post Number: 9 Registered: Jul-06
| Posted on Friday, August 04, 2006 - 04:41 pm: |
its only one subs that can be wired to 2ohms or 8ohms so which model should i go for T or V let me know if any of u have these amps |
Post Number: 1662 Registered: Dec-05
| Posted on Friday, August 04, 2006 - 05:00 pm: |
damn i must be drunk hehe, if you have one dual 4 ohm then yes get the a800t or V... get the cheapest one |
