Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Kicker comp cvr12
Author Thread: Kicker comp cvr12
Username: Kbugg0041891
Wut up, if i buy 2 kicker compcvr 12" subs already boxed with a sound storm 1200 watt amp with 300 watt tweeters and an amp kit for $290 brand new is that a good deal? and will it hit hard??
woops sorry a 1600 watt amp with 320 wat tweeters not 1200
Username: Dustin3
Tigard, OR
U.S.
Post Number: 2880
lol
you need to be more specific:
1200 watt amp = prolly means max (brand, model)
300 watt tweeters... = also max prolly, brand model
amp kit brand new? and should be 4 awg
haha aight dude my bad if i buy the 2 kicker comp cvr 12" already boxed also with a 1600 watt soundstorm amp with 320 watt tweeters is $290 a good price for all of that and its all new ....... and would this setup hit hard??
Username: Dustin3
Tigard, OR
U.S.
Post Number: 2883
sry man. lol
wut i meant, is whats the model brand etc for the amp and tweeters
Post Number: 8
the amp modle is the soundstorm f-2800 with stingpro tweeters
Username: Furyous
Miami, FL
Kicker makes excellent woofers, no matter what the price range. Soundstorm tends to overrate their products (as do many manufacturers). Often that 1600 watts is with 14.4 volts running into it at 1% or more distortion levels and at peak output. The amp will work fine, however. If you can hold out for a while, you can get some amazing deals on EBay. I have built all 3 of my car systems using stuff bought used and new on EBay. For $290, you can get much better stuff. look for amps by Fosgate, Kicker, Audiobahn, even COustic has nice stuff cheap. Boxes are dirt cheap too.
Post Number: 10
yeah thats were this deal is on ebay but the amp comes with it but i couldnt find all the other stuff cheaper.....so i should stick with the subs?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1643
it will probably suck, you should get those CVRs alone, make yourself a box, get hifonics 1206d and buy 2 pairs of infinity reference components, with a 4 channel amp from PPI or another company, then you should be ok...
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 8352
no sir...horrible deal
Username: Furyous
Miami, FL
Try this instead- I did some looking on EBay for an awesome system for much less- Start with the box. I assume you were looking for something good looking with a plexiglass window- This is a dual bandpass enclosure for 2 12" subs (auction #120014346010)if you do not want to build it yourself $24.99/ $45 shipping. Check out these Alpine subs SWR-124d's (auction #130012868874)- auction not over yet, shipping $73.95. Amplifier- Kicker 350.2 (auction # 180012432928) $99.50/$25 shipping. That brings you to $267 without the cost of the subs- You should be able to get these for $50 or so with that high of shipping costs. Even if you get them for $100 you will be spending less than the $290 plus $82 shipping on your auction, with much better stuff. You should have extra $ to spend on good, quality wiring. This system would have the ability to shake the fillings out of your teeth or just sound damn good.
Good luck. Let us know how it comes out.
Username: Tjmutlow
Post Number: 2660
its just ok but make sure those are the dual 4 ohm version of the subs. i would try ebay and get a better amp, you can find the 05 versions of these subs for 126 shipped. and find a better amp, and forget about 3 dollar tweeters.
Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Kicker comp cvr12 [ « Previous ] [ Next » ]
