Thread: Jensen -VM9511TS good/bad? Seems to have a lot of features |
New member Username: Adbraz
Rio de janeiro Brazil
Post Number: 8 Registered: Dec-05
| Posted on Thursday, August 03, 2006 - 09:31 pm: |
I know ppl have bad feeling about this brand, but this dvd seems damn pretty cool. Does anyone has it or know anything substantial about it? |
Bronze Member Username: Psychedelic_feta
Montreal,
Quebec
Post Number: 19 Registered: Oct-06
| Posted on Thursday, October 26, 2006 - 02:13 am: |
It's freakin amazing! The one and only problem I have with it from time to time is it doesn't connect to my iPod properly and I have to reset the unit, that's all! If you want every little detail ask me. |
New member Username: Celery504
Post Number: 2 Registered: Nov-06
| Posted on Monday, November 06, 2006 - 10:41 pm: |
how's the Jensen VM9021?? |
New member Username: Dondi3go
| Posted on Sunday, November 12, 2006 - 06:23 am: |
I wan to buy this unit but the thing that stops me is that i want to atach my pda the video would be no problem but i would like to use the touch screen to control the pda's GPS functions have you opened your unit up? to see the inside of it,... or if you could look in your paper work or unit for the FCC iD so i can search for the schematics online to see how the internals are hooked up all your help is apreciated |
Post Number: 3 Registered: Nov-06
| Posted on Sunday, November 12, 2006 - 06:25 am: |
sorry for double posting i found a touch screeen indash unit but is would have to be sent from china and if its defective it would be a head ache to return  |
