Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > 2 amps....rca connect or no?
Author Thread: 2 amps....rca connect or no?
Username: Afroopuff
Post Number: 168
If your running a 2 amp system, one amp for the 2 subs and 1 amp for your speakers....do rcas need to be connected directly from amp to amp?
Username: Afroopuff
Post Number: 169
is this what a crossover is for? i place the crossover after the headunit and before the amps, and the crossover splits them?
Username: Illuminator
Post Number: 3811
Daisy chaining the amps?
I would only do it if the head unit doesn't have seperate pre-outs for the sub and fronts/rears.
Username: Afroopuff
Post Number: 170
actually not a head unit, its gonna be a hi-lo....so does that mean i have to "daisy chain" the amps?
Username: Afroopuff
Post Number: 171
the Hi-lo is actually an LC6 though, it has different outputs for front rear and sub
Post Number: 3817
Yeah, use the outputs for the front and sub. If you want to daisy chain the amps, try it and see if you like it better.
Username: Afroopuff
Post Number: 174
thanks man, i apreciate all your help the last couple days, youve answered a lot of my posts
Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > 2 amps....rca connect or no? [ « Previous ] [ Next » ]
