Thread: These amps any good at all? |
Silver Member Username: Big_fletch
Newport, Ar,
Ar
United states
Post Number: 319 Registered: May-06
| Posted on Thursday, August 03, 2006 - 02:25 pm: |
hifonics bxi 2006 2000 watt amp and a hifonics bxi 2006 1600 watt amp............do these amps really put out 2000 and 1600 RMS watts!!! cuz i had a 1600 watt power acoustik amp that only did like 650 to 700 and does these hifonics amp get hot when they are at 1 ohm? |
Silver Member Username: Logan__tille
Hamilton,
Indiana
United states
Post Number: 608 Registered: Feb-06
| Posted on Thursday, August 03, 2006 - 03:07 pm: |
hifonics are good, they are a bit underrated, they do around 80% of there rated power.... |
Newport, Ar,
Ar
United states
Post Number: 321 Registered: May-06
| Posted on Thursday, August 03, 2006 - 04:06 pm: |
bump |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 2579 Registered: Feb-05
| Posted on Thursday, August 03, 2006 - 04:10 pm: |
they are overrated, not underrated Logan if they only do 80% of their rated power, lol. |
Newport, Ar,
Ar
United states
Post Number: 322 Registered: May-06
| Posted on Thursday, August 03, 2006 - 04:20 pm: |
well what amp should i get then cuz im gettin a atomic apxx 18 subwoofer are they really good subs and better than 15 L7's? anyways what amps should i get to go with that sub im wantin to get like 4 amps to put on the sub or 2 or 3 but i want them to have alot of power in them so what do yall suggest for a good price? |
Bronze Member Username: 98auroradkm
Post Number: 27 Registered: Jun-06
| Posted on Thursday, August 03, 2006 - 05:20 pm: |
I've heard the 2006 hifonics actually do their rated power now. |
Gold Member Username: Thomas_g
NM
Post Number: 1461 Registered: Oct-05
| Posted on Thursday, August 03, 2006 - 06:02 pm: |
PA amps are ok but id rather go with Hifonics. |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 942 Registered: Mar-04
| Posted on Thursday, August 03, 2006 - 06:32 pm: |
Someone on ca.com had their 1606 benched at 1300w. Not sure on the voltage, but that would indicate that 20% over rated is about right. Still a pretty good amp considering the price. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1616 Registered: Dec-05
| Posted on Thursday, August 03, 2006 - 07:03 pm: |
well opti that's kinda weird, cuz bassman saw one doing 1500w+ hehe, but they're still overrated. Lil rob told you about the sub tyler?? |
Newport, Ar,
Ar
United states
Post Number: 325 Registered: May-06
| Posted on Thursday, August 03, 2006 - 07:05 pm: |
yea he told me bout the sub why u ask |
Newport, Ar,
Ar
United states
Post Number: 328 Registered: May-06
| Posted on Thursday, August 03, 2006 - 07:13 pm: |
is that apxx 18 a really good loud sub.....would i beat the hell outta my 15 L7 |
Newport, Ar,
Ar
United states
Post Number: 329 Registered: May-06
| Posted on Thursday, August 03, 2006 - 08:22 pm: |
bump |
Newport, Ar,
Ar
United states
Post Number: 331 Registered: May-06
| Posted on Thursday, August 03, 2006 - 09:27 pm: |
bump again |
Lawrence,
Ks
Post Number: 945 Registered: Mar-04
| Posted on Thursday, August 03, 2006 - 11:46 pm: |
bench tests always vary. Ever seen two birthsheets that are exactly the same measured power?? I'm sure such a thing has happened somewhere, but I've never seen it. Just because one amp does xxxx watts, doesn't mean the next one off the line won't do 20% more. Also, unless the power's measured using an 0-scope to monitor clipping, THD and the Voltage being supplied - who knows how accurate the measurement really was. So - it seems they're a little over-rated, but close enough to be pretty good amps (power-wise) for the cost. |
Silver Member Username: Halter
Paulding, Ohio
Post Number: 192 Registered: Oct-05
| Posted on Friday, August 04, 2006 - 12:16 am: |
I have a Hifonics 1606D and I can't run it with stock alternator at a idle...also...it blows 80 amp fuses like no tomarrow..lol...also I am runnin her at 1 ohm...to a 15" mojo and I prolly drove 2 hours...going at it...and the amp was warm...but not hot at all...shes was doing good I was impressed!! |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 8744 Registered: Jul-05
| Posted on Friday, August 04, 2006 - 12:44 am: |
y do u have a 80A fuse on a '1600wrms' amp ?? my mb quart raa1000 1000wrms had 3 40A fuses on it & never blew any fuse/s on my distro block ..... |
Newport, Ar,
Ar
United states
Post Number: 335 Registered: May-06
| Posted on Friday, August 04, 2006 - 01:22 am: |
lol halter start using 100 to 120 amps on the fuse then u should be fine |
Post Number: 1634 Registered: Dec-05
| Posted on Friday, August 04, 2006 - 11:32 am: |
exactly, get one 120A fuse... |
Post Number: 28 Registered: Jun-06
| Posted on Friday, August 04, 2006 - 11:45 am: |
that amp is set up for 80A x 2 |
