Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Digital designs 10" subs
Author Thread: Digital designs 10" subs
Username: Dub_c
Post Number: 125
So here I am, STILL wondering which good 10" subs to get, here is what I asked on the DD forum: What is the recomened space need for these subs in a SEALED box? How much do they cost?
Thanks
HERE are what people have replied:
1.Around 1 cube, but they dont perform well in sealed. If you can get 1 cube then add a port(unless you really want sealed) You will over double the output of the subwoofers.
2.I have 2 off the 1010 running and they do so much better in a ported box than a sealed one.
I have both off them running on 500w rms but they can take so much more so i am waiting for the new amp's so i can put a M1A on both off them.
I have a few box sizes but they are in cm or liters
1: 1 box for 2 sub's 60 liters with a port off 5cm x 25cm x 45cm
2:2 boxes both 30 liter port sizes 3cm x 25cm 70cm you can al so change the port to:
- 2,5cm x 30cm x 70cm
- 2 cm x 37,5 cm x 70cm
The boxes are excl wood so incl you will get about 45liter
3.it sounds like crap don't put it in a sealed box...if ur gonna put it in that then u mite as well get some other brand like kicker or something. dont put a dd in there
Theres more, but you get the idea! 1 cu. ft is WAY TOO MUCH for 10's. So is this TRUE, that they dont sound good in a SEALED box?
HERE is what I am looking for, 2 10" subs, 350-400WRMS each, sound good in a sealed box, single 4 ohm or dual 2 ohm.
Username: Logan__tille
Hamilton, Indiana
United states
Post Number: 604
you can call and ask em...
Username: Rzarector
Coquitlam, Bc
Post Number: 1235
some subs arent well suited for sealed enclosures some arent for ported... for what u want sounds like a w6 would be perfect.. excellent sq work well in small enclosures 400w rms
Username: Basshead86
Google is your Friend, FL
Post Number: 4191
1 cubic foot is not to much for a sealed 10.
my 10 is in almost 2 cubes ported.
i replied in that thread as well.:-) - J.T.2510
Nick@SickAudio posted something earlier about testing one in a sealed enc. from your inquiry. said it sounded awesome and Wanged.:-)
Post Number: 4192
check out Image Dynamics subs. the ID and IDQ.
they take VERY small boxes and can handle 300wRMS.
Username: Dub_c
Post Number: 126
Image Dynamics, which one is better the ID or IDQ? So are these LOUD and CLEAN?
Username: Dub_c
Post Number: 127
Wait, these things are expensive huh! I cant go to their shop page.
Username: Ctmike
Ct.
Post Number: 1212
cardomain has 12"s, no 10"s though and there pretty cheap, if you want 12"
http://www.cardomain.com/shoplist~b~Image+Dynamics~t~Subwoofers
Username: Dub_c
Post Number: 129
These look nice:
http://www.cardomain.com/item/IDSID12V3D2
5/5, but are they good for only being $100?
Are THEY LOUD and CLEAN?
Post Number: 4200
they are def. some of the cleanest drivers i have ever heard. and extremely accurate. they are very efficient so they get pretty loud for the amount of power in them.
Username: Dub_c
Post Number: 130
For real?!
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1671
if muddy said that, get it for sure
Post Number: 4213
dude, image dynamics is one of the best subwoofer companies when it comes to SQ subs.
their lower line may not get as loud, but it is still a subwoofer that takes 3-400wRMS and has at least 14mm of xmax.:-)
Username: Dub_c
Post Number: 131
What other websites sell Id's?
Post Number: 4230
here is the biggest list of sellers i could find. lol
http://www.google.com/search?hl=en&q=image+dynamics+subwoofers&btnG=Google+Searc h
Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Digital designs 10" subs [ « Previous ] [ Next » ]
