Thread: CDT Audio KA-61 vs. Phoenix Gold ZR6.5COMP |
Bronze Member Username: Chornet44
Post Number: 17 Registered: Jul-06
| Posted on Wednesday, August 02, 2006 - 12:52 pm: |
witch one do you think would be better for my PT Cruiser powered by a EA2000...i listen to rap and r&b but i like the SQ nice clean sound KA61 2-way Component set 100Watt rms FR 65-20kHz. Sensitivity: 91 dB. X-over: 12 dB. clear top housing Surround: Buytal rubber. Tweeter:1" Dome, Film material Silk Suspension: Flat Cone: COC (cyclo-olefin-copolymer) Phoenix Gold ZR6.5COMP 70 Watts RMS (140 per set) FR 65Hz-20kHz Sensitivity: 90db Aluminum-Plated, Injection Molded, Polypropylene Cone pair of Pivoting 25mm Silk Dome Tweeter Ferro-Fluid Filled Neodymium Tweeter External 24 dB per Octave Acoustic Crossover for the best sounding highs and mids around |
Post Number: 19 Registered: Jul-06
| Posted on Wednesday, August 02, 2006 - 08:48 pm: |
anybody here know about these? |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1122 Registered: Jan-06
| Posted on Wednesday, August 02, 2006 - 11:12 pm: |
how much are you looking to spend. I'm a dealer for CDT and have a set of EF-61 with upgraded crossover and tweeter available for 230$ shipped in 48states for forum members. It has the 560 crossover and 1in drt-25 tweets. |
Post Number: 20 Registered: Jul-06
| Posted on Thursday, August 03, 2006 - 12:40 am: |
thanks for the offer but im only willing to part with about 150 bucks for the fronts is there any other good brands for cheap that i should look into? |
