Home > Message Board > Car Audio > Speakers > Archive through August 13, 2006 > Any suggestions
Author Thread: Any suggestions
Username: Nyyfan13
im new to car audio so sorry if these questions suck but im gettin a jl w6 and a 500/1 jl amp and putting the sub in one of those jl HO boxes. im also lookin for a new headunit and 4 speakers, 2 5 1/4 and 2 6 1/2. any suggestions on cheap but quality speakers or headunits. doesnt have to be realy cheap, maybe $200 for each set of speakers, and another $200 for a headunit. thanks for any help you can give me
Username: Bigsim
Australia
Post Number: 143
What kind of car are they going in? Unless you really really want rear fill, I (and a lot more people more knowledgeable than me) would suggest you at least consider dropping the idea of the two sets, and instead forking out for a really nice set of front components.
Username: Nyyfan13
Post Number: 11
their going into a scion tc. i posted this message on the subwoofer site and they recommened that i get these.
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2949
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2950
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=445
Username: Dkchillin
Vermont
Post Number: 216
Infinity makes a nice speaker, but make sure you get out and listen to them if you can since they tend to be very "bright" and most people love them or hate them. I personally run Polk DB 5250 5 1/4 components, but I also like the sound of Boston Acoustic as well. The most important thing in buying speakers is to get out and take a listen to as many as you can since everyone likes different things.
As far as a deck under $200, you may want to look into the Pioneer Premier deh-p480mp or deh-p580mp. Here are some other options. You can get all of those decks for cheaper if you look elsewhere.
Home > Message Board > Car Audio > Speakers > Archive through August 13, 2006 > Any suggestions [ « Previous ] [ Next » ]
