Thread: New components. |
Silver Member Username: Crayola0
Wisconsin
Post Number: 362 Registered: Jun-06
| Posted on Tuesday, August 01, 2006 - 09:32 pm: |
I have a 199 dodge durango and all the speakers are blown and i dont know what kind they are. they are infinity but i dont know if they are coxial or midranges and that. and i dont know how to install them cause they have a plastic piece attached to the door that only has 3 screws and a plastics grill built into the plastic door cover to hide the speaker. |
Wisconsin
Post Number: 400 Registered: Jun-06
| Posted on Friday, August 04, 2006 - 10:16 pm: |
anyone? |
Wisconsin
Post Number: 479 Registered: Jun-06
| Posted on Wednesday, August 09, 2006 - 10:08 am: |
anyone? All i know is that the speaker has to have 3 Tabs that snap into a frame thing. |
Bronze Member Username: Riskyb
Post Number: 68 Registered: Feb-06
| Posted on Wednesday, August 09, 2006 - 07:23 pm: |
1. Go to your local stereo shop. 2. Ask them to look at your vehicle 3. Listen to what they reccomend You don't quite know enough for us to help you lol. |
Wisconsin
Post Number: 494 Registered: Jun-06
| Posted on Wednesday, August 09, 2006 - 11:30 pm: |
lol...if the charge me for them to look at it im gunna be so mad..lol |
Silver Member Username: Dkchillin
Vermont
Post Number: 234 Registered: Mar-05
| Posted on Thursday, August 10, 2006 - 02:21 am: |
search online for a Dodge Durango forum and check their car audio section for information on your system. There's a vehicle specific forum for nearly every car out there, you're bound to find the info you're looking for or at least someone who can walk you through the process. |
New member Username: Sonyxplode
Post Number: 3 Registered: Aug-06
| Posted on Thursday, August 10, 2006 - 04:16 pm: |
get sony components |
Silver Member Username: Justababyboy
Philly,
PA
Post Number: 118 Registered: Jun-05
| Posted on Thursday, August 10, 2006 - 05:23 pm: |
Why don't you just take the door panel off yourself...it is fairly easy..there are guides on crutchfield on how to do this |
