Thread: System layout. Tell me what you think |
New member Username: Youngc32587
Post Number: 1 Registered: Aug-06
| Posted on Tuesday, August 01, 2006 - 09:12 pm: |
I have finally decided all the parts of my new system. I have one 12" Rockford Fosgate Power HX2(1000w RMS) http://www.cardomain.com/item/ROCRFR3112 Want to add the Rockford Fosgate 801s http://www.cardomain.com/item/ROC801S With this box http://www.mainstreet-audio.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code= ZV112-2030&Category_Code=ENC12type3 (tuned to 30hz) (not sure about the box, any suggestions feel free to elaborate on them) I think this combination would be excellent. What do you guys think? |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 2565 Registered: Feb-05
| Posted on Tuesday, August 01, 2006 - 09:56 pm: |
that amp will power the sub fine. i wouldn't get a prefab box though and i definally wouldn't pay $130 for a prefab box!! you can make one for close to $40. and you really don't have a way of telling what that box will be tuned to since its not built to spec using the sub parameters...most end up being tuned really high when you add whatever sub so you'll loose a lot of SQ. |
Post Number: 2 Registered: Aug-06
| Posted on Tuesday, August 01, 2006 - 10:11 pm: |
So you think I should get a local car audio place to build it just for my speaker because I know I cant built a good enough 1. The speaker requires at least 2.0 cu. ft of space. Thats pretty big going into the trunk of my 96 geo prizm |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1612 Registered: Dec-05
| Posted on Wednesday, August 02, 2006 - 10:18 am: |
chris, talk to ATF, he can make a nice box for you, for less than 130$, i'm sure of that |
Stockbridge,
GA
Post Number: 2584 Registered: Feb-05
| Posted on Thursday, August 03, 2006 - 04:25 pm: |
a local store will prob charge you an arm and a leg too. could you do it yourself?? you'd save a ton of money that way. |
