Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Audiobahn A8005DN Good For 2 10' Alpi...
Author Thread: Audiobahn A8005DN Good For 2 10' Alpine Type S?
Username: Wrjh12
Post Number: 13
I Just Recently Purchased 2' 10 Alpine Type S Subs. I have just started putting in car audio products. And I would appreciate you opinion on the Audiobahn A8005DN, also I have a downfire ported box if that makes any difference
http://www.crutchfield.com/S-kG5XPQDAcjh/cgi-bin/ProdView.asp?g=120&I=037A8005D Thank you.
Username: Ctmike
Ct.
Post Number: 1203
i'd get a better amp, one that does 600-800wrms, depending on the subs vc.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1599
a-bahn a8000v
Username: Wrjh12
Post Number: 14
Yea I Kinda changed my mind on the Audiobahn Amp, Unless yall think this is the one to go. I just dont think Audiobahn makes good amps. But as i said if you have another opinion let me know.
Thanks
Josh
Username: Ctmike
Ct.
Post Number: 1209
what's your budget? here's a few:
http://www.speedsound.com/product.asp?specific=jnkpmpqpo
if you have 2ohm dvc:
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16918
Username: Wrjh12
Post Number: 16
My Budget is like preferally 100-200 i guess
Username: Adam_s
Post Number: 54
audiobahn amps arent that bad they are actually good budget amps. Depending on the voice coil you could either get the audiobahn a8000t or a8002t they cost around 130 on ebay and are a good amp.
Username: Blazerboy
Post Number: 101
I picked up a a8002v on ebay for $140 shipped. Its a great amp, and for that price it cant be beat.
Username: Riskyb
Post Number: 16
http://www.sonicelectronix.com/item_4116.html
That will push them decently if you wire it at 2 ohms. I would rather have that than audiobahn.
Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Audiobahn A8005DN Good For 2 10' Alpi... [ « Previous ] [ Next » ]
