Thread: After market amp and subs installed, got some problems. |
New member Username: Flyboyy
Post Number: 7 Registered: Jul-06
| Posted on Tuesday, August 01, 2006 - 09:48 am: |
please goto this link and read my problem, I really dont want to type retype it, I am just posting the problem in a few forums and hope someone has an idea on what my problem is thanks for looking. http://www.bimmerfest.com/forums/showthread.php?t=158584 |
Gold Member Username: Illuminator
Post Number: 3752 Registered: Apr-05
| Posted on Tuesday, August 01, 2006 - 09:59 am: |
Yeah, I also think it's a gain problem. Have you tried bridging the amp? The 150x2 is max power, isn't it? |
Post Number: 8 Registered: Jul-06
| Posted on Tuesday, August 01, 2006 - 10:03 am: |
I am not good with amps, the brand is a lightning bolt 150.2 thats all i know and it looks like 150x2 is max. how do you bridge an amp ? and how do i fix the gain's problem ? |
Post Number: 3756 Registered: Apr-05
| Posted on Tuesday, August 01, 2006 - 10:10 am: |
You connect (usually-consult the owner's manual first) the left channel positive wire as the positive speaker wire and the right channel negative wire as the negative speaker wire. The gain or input sensitivity is a small knob on the amp that usually needs a small flathead screwdriver to turn (sometimes it's just a knob you can turn by hand). Try turning it up to see if you get more volume out of the speakers. |
Post Number: 9 Registered: Jul-06
| Posted on Tuesday, August 01, 2006 - 10:35 am: |
thank you, i will chech it out tonight and let you know. |
Post Number: 10 Registered: Jul-06
| Posted on Tuesday, August 01, 2006 - 07:19 pm: |
I have solved the problem, after carefully examining the wiring, I realize that i forgot to ground the cable from the amp , I was really rushing last night because it was getting late and I did not have dinner ,but my amp is pumping now , I came across another problem is all the bass is trapped in the trunk , i want to get the bass into the cabinet of my car, I have a bmw 2003 530i, and there is an armrest where there is option for ski's to go but my car does not have that option so the metal is not cut, I was wondering if anyone knows how i can get the bass from the trunk to the cabinet for greater sound. |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 8713 Registered: Jul-05
| Posted on Tuesday, August 01, 2006 - 08:02 pm: |
im not familiar wit how ur car is inside but ppl some 'port' the rear deck meaning cut out holes in it so that bass passes through ... |
