Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > What Amp To Buy - Please Help
Author Thread: What Amp To Buy - Please Help
Username: Kingers
Melbourne, Victoria
Australia
Hey,
I need some help, i need to know wat sort of an amp i would need to buy if i wanted to put a Sony Xplode 1000 watt 12 inch sub in my car plus 170 watt 6 inch speakers using a 200 watt Kenwood cd player.
I dont really know much about this sort of stuff so any advice would be good, like how many chanels and stuff like that. Thanks heaps
Username: Ctmike
Ct.
Post Number: 1191
you need to post the rms of the subs/speakers, and budget. and why a sony sub, you didn't buy it already did you?
Username: Kingers
Melbourne, Victoria
Australia
The speakers are 170W (40w rms) and i dont really know what the sub rms is
Watts MAX. Music Power 1000 Watts
Watts Nominal Power Handling 400 Watts
I found that if it means anything
No i havent brought them yet but i am thinkin of buyin em cause they are cheap. The cheapest possible option for the amp would be good, i dont know the prices of em. so yer. Thanks
Username: Ctmike
Ct.
Post Number: 1194
how much you want to spend on subs/amp? i'd highly recommend you not buying sony, their cheap cause they suck.
Username: Illuminator
Post Number: 3758
Whoa, the original poster made a triple post haha
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1589
check kicker cvr, AA assassins, even pioneer if you're that bad...
Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > What Amp To Buy - Please Help [ « Previous ] [ Next » ]
