Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Which amp to get?
Author Thread: Which amp to get?
Username: Rzarector
Coquitlam, Bc
Post Number: 1230
sorta tossed up between these 3 choices..
2 alpine mrd m1005 .. cause the price is right
2 phoenix gold xe 1200.1's
or 1 JBL BPX 2200.1 2200 watts at 4 ohms :o
dont wanna run lower than 2 ohms.. but any other choices are welcome.. looking to spend 1200 max
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1581
well bro i'd go with the xenons, just because the wiring options are there hehe, but the JBL is a great choice too, go with xenons
Username: Rzarector
Coquitlam, Bc
Post Number: 1233
only think that turned me off those was i have herd of bad batch problems...
Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Which amp to get? [ « Previous ] [ Next » ]
