Thread: Which amp to get? |
Gold Member Username: Rzarector
Coquitlam,
Bc
Post Number: 1229 Registered: Dec-04
| Posted on Monday, July 31, 2006 - 11:15 pm: |
sorta tossed up between these 3 choices.. 2 alpine mrd m1005 .. cause the price is right 2 phoenix gold xe 1200.1's or 1 JBL BPX 2200.1 2200 watts at 4 ohms :o dont wanna run lower than 2 ohms.. but any other choices are welcome.. looking to spend 1200 max |
Bronze Member Username: Blazerboy
Post Number: 100 Registered: Jun-06
| Posted on Thursday, August 03, 2006 - 03:37 am: |
I have expierienced, and heard of great thing with the PG Xneon series. Personally I would go with a couple of those. |
Silver Member Username: Big_fletch
Newport, Ar,
Ar
United states
Post Number: 317 Registered: May-06
| Posted on Thursday, August 03, 2006 - 01:46 pm: |
i would go with the jbl |
Silver Member Username: Rick_ross
Post Number: 268 Registered: May-06
| Posted on Thursday, August 03, 2006 - 03:27 pm: |
id get the xenon |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 2582 Registered: Feb-05
| Posted on Thursday, August 03, 2006 - 04:16 pm: |
JBL or Xenons. Alpine amps aren't so hot. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1623 Registered: Dec-05
| Posted on Thursday, August 03, 2006 - 07:16 pm: |
i'd get the xenons cuz of the wiring options, you can put any sub and they'll get 1200-1300wrms all day |
