Thread: Qyestion A8000V.....???? |
Silver Member Username: Eseesai
Post Number: 219 Registered: Mar-06
| Posted on Monday, July 31, 2006 - 05:00 pm: |
does anybody know if it puts out what its says or are they overrated???? |
Gold Member Username: Dustin3
Tigard,
OR
U.S.
Post Number: 2849 Registered: Oct-05
| Posted on Monday, July 31, 2006 - 05:11 pm: |
it puts out ,lol |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1553 Registered: Dec-05
| Posted on Monday, July 31, 2006 - 05:13 pm: |
800w rms or a lil more |
Silver Member Username: Blazerboy
Post Number: 102 Registered: Jun-06
| Posted on Thursday, August 03, 2006 - 03:48 am: |
Yea I have a a8002v, and it puts out what, if not more than its supposed to. |
Post Number: 220 Registered: Mar-06
| Posted on Friday, August 04, 2006 - 05:54 pm: |
ok so i got the amp already now i need help on installing it i got the 4gauge wire and the i need the ground the rca and the remote turn on where i can ground it cause the amp is gonna be in the trunk and i dont know where and i dont really know how to install the remote on the battery i know and the rca i know how can anyone help me please!!!! |
Gold Member Username: Tjmutlow
Post Number: 2666 Registered: Sep-05
| Posted on Friday, August 04, 2006 - 05:56 pm: |
the remote should go to the back of the radio, or into the fuse block on switched power, not to the battery. alos about 1-2 ft for ground, scrape to bare metal on chassis... |
Post Number: 1664 Registered: Dec-05
| Posted on Friday, August 04, 2006 - 08:14 pm: |
12V goes to the battery |
Bronze Member Username: Riskyb
Post Number: 33 Registered: Feb-06
| Posted on Saturday, August 05, 2006 - 01:29 am: |
What kind of truck is it and where do you intend to mount it? I had to put my amps on the back of my seats in my single cab F150. I just grounded to the bolts on my seats. Put a ring terminal on the wire then unscrewed the bolt put it through the terminal and tightened it back down. This also works if you put the amp under the seats. |
Post Number: 34 Registered: Feb-06
| Posted on Saturday, August 05, 2006 - 01:30 am: |
My bad I mixed this post up with another. If the amp is in your trunk use the bolt that holds your spare tire if you got it. |
