Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Another hifonics question
Author Thread: Another hifonics question
Username: 98auroradkm
Post Number: 22
I was thinking about getting a hifonics brutus 1606 to power my two 800 watt rms 10's that are 6ohm and have 3" dual voice coils. I have been looking at other threads and saw that hifonics tends to be overrated. With that being the case, will this amp power my subs good, or should I look elsewhere? I really just want something under $300 that will make my subs pound.
Username: Dustin3
Tigard, OR
U.S.
Post Number: 2844
you would be underpowering them, but it would work alright
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1536
Bass, i don't think the system is going to sound great, the hifo is overrated at 1 ohm, imagine at 1.5, should be like 1200w rms. Try getting a real 1600w rms or more...
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1537
i'd pick soundstream pca 2000d, remember, set your gain to the HU preamp voltage
Username: Dustin3
Tigard, OR
U.S.
Post Number: 2845
hes not wiring to 1.5 ohm tho, that would jus decrease the overall output
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1539
he can only wire to 1.5 parallel or 6 ohm series
what's happening with the PHD bro?? hehehe, i bet you got affected from Mick and Soprano haha
Username: Dustin3
Tigard, OR
U.S.
Post Number: 2846
lol. i didnt see the ohm load of his subs. my bad. i;m not good with parallel and series wiring anyways, like how to find it out.
you can tell me on j designs, lol
Post Number: 23
I looked up that soundstream and the cheapest I saw was like 400 on ebay, I was looking for under 300, the hifonics was more in my price range thats y i considered it, gotta save up to go back to school in the fall.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1541
check this one, power acoustik a3000db, good budget amp
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 8281
do u have audioburn subs???because thats what those sub specs remind me of
Post Number: 24
yea lol
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1542
hahahahhaha...
Username: Stereoproz
Post Number: 7
yeah get power acoustik, or I mean Kole, or I mean Planet Audio, yeah that's it there's a real ball buster amp
http://ampguts.realmofexcursion.com/Power_Acoustik_A3000dB/
Post Number: 25
well... i went ahead and got the hifonics amp. I read some other reviews and it seems like it could pound my subs so thats whats up. thanx anyway
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1597
you're going to underpower them, you'll see, cuz the amp will put the power at 1 ohm, and your subs are at 1.5, good luck
Username: Dustin3
Tigard, OR
U.S.
Post Number: 2864
you will be givin them around 500-600 each. and stereoproz is the same guy that went around yesterday posting all of the amp guts pics :-)
Home > Message Board > Car Audio > Amplifiers > Archive through August 06, 2006 > Another hifonics question [ « Previous ] [ Next » ]
