Thread: What's a good 1000w amp? |
Bronze Member Username: Erikdagenerik
Livermore,
CA
US
Post Number: 74 Registered: Aug-05
| Posted on Sunday, July 30, 2006 - 10:04 pm: |
I need a recommendation for a 1000 watt amp stable at 1 ohm. It's powering an IDMax. I used to use a piece of garbage Hifonics amp, and it ended up cutting out every now and then so I'm using my backup Diamond Audio setup, but I want to go back to the IDMax. I don't want to spend as much on a JL 1000/1. As long as it won't end up like the Hifonics did, I'll be happy. Thanks for any suggestions. |
Bronze Member Username: Feaiel
Post Number: 19 Registered: May-06
| Posted on Sunday, July 30, 2006 - 10:32 pm: |
Well, I'm guessing the RF T10001 is out then. Think it's along the same price range as the JL..May be able to find it a tad cheaper on line though. |
Silver Member Username: Showrides
Hartford,
CT
Post Number: 136 Registered: Feb-06
| Posted on Sunday, July 30, 2006 - 11:51 pm: |
Great deal right now. Low price and will last you a minimum of 2 years. http://www.low-hz.com/commerce/catalog/product_info.php?cPath=22_31&products_id= 55 |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1515 Registered: Dec-05
| Posted on Sunday, July 30, 2006 - 11:52 pm: |
ED nine1, 350$ with a 3 years warranty |
Livermore,
CA
US
Post Number: 76 Registered: Aug-05
| Posted on Wednesday, August 02, 2006 - 04:11 am: |
I'm going to go with the ED nine1. I've had good experiences with eD before and I have friends that have had them as well. I need something with good warranty. amps are electronics, and they're bound to fail when you push them hard enough. |
Silver Member Username: Atllefty12
Pinellas,
Fla.
Post Number: 167 Registered: Jul-06
| Posted on Wednesday, August 02, 2006 - 07:55 am: |
that rf amp runs u around 400 |
Post Number: 1607 Registered: Dec-05
| Posted on Wednesday, August 02, 2006 - 10:09 am: |
the rockford is very underrated and will put like 1600w rms, IDK if that sub can handle all the power, but they're both good amps, rockford and nine 1 |
