Thread: Possible fix for HU Wine! |
Bronze Member Username: Clouduz
Post Number: 79 Registered: Jun-06
| Posted on Sunday, July 30, 2006 - 06:19 pm: |
Ok, after about a week of trouble with the alt noise i finally fixed it! Hopefully this way will work for others. Ok, not sure if you need one b/c I was soo happy when i got rid of the noise to check. --A ground loop isolator, works on speakers but don't try to use on subs, you will get NO output. Ok now to the real deal....I put the ground loop filter closest to the amp (not sure if it makes a diff being behind the HU. Ok, then the noise was still present but lower. Next I put speaker wire BETWEEN the rca's behind the HU, and grounded them. Guess what, noise GONE!!! Now i'm ridin with my amp'd speakers and subs sorry, about the double category didn't know which category this belonged in. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1497 Registered: Dec-05
| Posted on Sunday, July 30, 2006 - 08:46 pm: |
haha, nice |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 2560 Registered: Feb-05
| Posted on Monday, July 31, 2006 - 06:30 pm: |
grounding the RCA's is common to fix noise, especially on some older Pioneer models that had grounding issues. |
Post Number: 82 Registered: Jun-06
| Posted on Monday, July 31, 2006 - 08:38 pm: |
well, guess what Brandon, it was a Pioneer 860MP |
Stockbridge,
GA
Post Number: 2566 Registered: Feb-05
| Posted on Tuesday, August 01, 2006 - 09:59 pm: |
yep, they were notorious for noise. newer ones seem to be fixed, hopefully they stay that way. 860 is a great unit though. |
