Home > Message Board > Car Audio > Speakers > Archive through September 22, 2006 > Big difference between Focal k2p's an...
Author Thread: Big difference between Focal k2p's and Utopia 165w's?
Username: Chitownz
Would love for some input and if you think the Phoenix Gold Xenon200.4 would be a good amp to power them. Any input would be helpful, thanks.
Username: Chitownz
Please, anyone know a thing or three about Focal?
Username: Johammbass
Cork, Cork
Ireland
Post Number: 267
I am not a great fan of Focal, but I know guys that will kill in the name of it:-)
Xenon is a nice amp for the money though:-)
Username: Chitownz
Post Number: 7
What comps do you like on the high end...ie above $400 but less then $1000?
Username: Theelfkeeper
Stockbridge, GA
Post Number: 2563
Rainbow speakers are amazing.
Focals take a lot of work, especially the tweeters, to get sounding nice. K2P's and Utopias are nice, anything lower is pretty bad, but for the money, i'd get some Rainbows. sounds all subjective though, so best thing to do is try and listen to them. usually pretty hard to do though...
Cork, Cork
Ireland
Post Number: 269
Well, that's a pretty good budget, so you could look at DLS, Morel, CDT, MBQ and many others (Rainbow's including)
Yeah it would help if you could listen to a few different ones.
Stockbridge, GA
Post Number: 2573
i'll throw Dynaudio and Seas out there too.
good stuff.
Username: Spidercoder
Palm Harbor, Florida
Post Number: 111
check out the diamond hex before spend tons of money. Then If you wanna spend some money check out zapco competition or the diamond d9 comps
Username: Glasswolf
Wisteria, Lane
Post Number: 11611
yes the K2ps are worth the difference in cost. they are very good components.
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 8973
"zapco competition or the diamond d9 comps"
wow..lol both of those are not all that great...
not sure why both of those compaines make great amps and sh!tty comps??? oh well
Username: Basshead86
Google is your Friend, FL
Post Number: 5975
MARIS!!!!!!!
definitely check out as many as you can....not even the high end....just as many as you can..to find out what "kind" of sound you like more....aggresive, bright....or laid back, warm sounding speakers.
most of the DLS are laid back and warm...i have heard some Focal's and they sounded very bright...also heard some Morels....veddy nice.
never heard any rainbows...but Brandon loved them. so definitely find out what "kind" of sound you want and then start asking about comps with that type of sound reproduction...like on www.elitecaraudio.com
LOTS of SQ pros there....they can definitely help you out.:-)
Stockbridge, GA
Post Number: 2949
if i recall correctly, the K2P's came out after the Utopias and are actually better. the Utopias have been replaced with the Be.x line.
Home > Message Board > Car Audio > Speakers > Archive through September 22, 2006 > Big difference between Focal k2p's an... [ « Previous ] [ Next » ]
