Thread: Blaupunkt IVDM-7002 region change |
New member Username: W72315
Post Number: 1 Registered: Jul-06
| Posted on Sunday, July 30, 2006 - 10:12 am: |
Hi All, I bought a region 1 Blaupunkt Chicago IVDM-7006 head unit from the USA and have just moved back Australia, where it's region 4. Does anyone know how to change the region code for this unit. It's a bit of a pain that everything else works except the DVD player. |
New member Username: Adbraz
Rio de janeiro Brazil
Post Number: 7 Registered: Dec-05
| Posted on Thursday, August 03, 2006 - 09:27 pm: |
isnt blaupunkt chicago IVDM-7002? (no touch screen) turn the thing on with the remote control press 1379 then ENTER (with remote control) Youll be driven to a menu down the screen and just go and swich things... |
New member Username: Audiowerks
NYC,
NY
Post Number: 1 Registered: Dec-06
| Posted on Friday, December 08, 2006 - 05:11 pm: |
Hello All, We have the Blaupunkt in-dash nav unit for a VW Passat (a touch screen). It is a european unit and we moved to the states, so it cannot read the region on the DVD. The nav is region 2 while the DVD-ROm is region1. Does anyone know how to change the region code on the unit? Many thanks in advance |
