Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2006
  Thread Last Poster Posts Pages Last Post
Go0d bad okJC2006-07-23  15:58 ET
New amp won't turn onMick2006-07-23  15:10 ET
Amp stopped working...Mick2006-07-23  15:02 ET
HELP!!!! 3000 watt sub and 3000 watt ampJexx2006-07-23  14:33 ET
Alternative use for a car amp... maybe?Jexx2006-07-23  14:31 ET
Looking for an amplifier eddylabrada2006-07-23  13:58 ET
2 Channel Amp Setuppaul klukas2006-07-23  13:50 ET
I Need A Amp... Please Help mat dope2006-07-23  11:49 ET
3 SONY 12'S ONE SONY 2CHANNEL AMPeddylabrada11 2006-07-23  11:24 ET
What to do?CadillacDb2006-07-23  03:40 ET
Good 1ohm stable amp? 500-600watts?killer2006-07-23  02:28 ET
MemphisRobbie Kush2006-07-23  00:42 ET
OT: saving money lolderek smith55 2006-07-22  23:12 ET
BS.P.D15 2006-07-22  22:34 ET
Overallsystem Question about voltagerobert geiger10 2006-07-22  22:23 ET
Amp questionSteven Norris2006-07-22  18:48 ET
How do i find the pre amp voltage?Troy Stafford10 2006-07-22  18:31 ET
How do i connect a 240v home amp to my car head unitTroy Stafford2006-07-22  18:29 ET
Good System for around 3000$?Kevin Holden18 2006-07-22  17:13 ET
AMP help please =0Jesse D2006-07-22  14:20 ET
Alpine vs Soundstreammat dope16 2006-07-22  10:45 ET
Need answer before buying...will this amp power a 12w6?Steven Norris12 2006-07-22  02:39 ET
4 CH amp setupIcePick2006-07-22  02:37 ET
Which Amp for 2 Alpine SWR-1041D 4 Ohm DVC SubsChauncey Drinon10 2006-07-22  00:06 ET
Worth it IITroy Stafford15 2006-07-21  23:44 ET
Question Phoenix Gold RSD amps....Jim Mack2006-07-21  23:42 ET
Pro's only. Whats the best amp out of this selection? List amp's f...G_Money10 2006-07-21  16:40 ET
Kicker 4 channel for saleCameron2006-07-21  11:18 ET
RCA to speaker wire help....flyboy2006-07-21  10:35 ET
Car amps at home plz helpIsaac2006-07-21  08:38 ET
Gain questionIcePick2006-07-21  02:07 ET
Need help with wiring!NVmyBOOM2006-07-21  00:53 ET
I've figured it out!!!!!!!!!!!!!Trevor Meyers2006-07-21  00:12 ET
ULTRA LINEAR UL3200DDevin Shannon2006-07-20  23:02 ET
What , if any is the difference....bassman311 2006-07-20  22:11 ET
Online dealer with a8000t in stockSteven Norris2006-07-20  21:54 ET
CLass A/B versus CLass DSteven Norris29 2006-07-20  20:52 ET
Just Curious...Steven Norris2006-07-20  20:42 ET
How Would You Tell If...Steven Norris2006-07-20  20:28 ET
WANTED!!!!!!!!!!! Soundstream amo that does 850-900 at 4 ohms.Joe Spose25 2006-07-20  19:32 ET
What is better.... ED nine.1 or directed d2400.................blaine westropp17 2006-07-20  19:13 ET
Logic Soundlab?????Trevor Meyers2006-07-20  18:46 ET
JL A series amps are outChauncey Drinon2006-07-20  18:31 ET
Real wattsChauncey Brown2006-07-20  18:05 ET
True rateingsMichael Cheatham2006-07-20  17:24 ET
Orion 2500d & Eclipse AVN5435 rca connection help neededsinx2006-07-20  16:32 ET
What amp is bestMaxSQ10 2006-07-20  15:12 ET
Hifonics bxi series amps rms ratings?Tank65852006-07-20  13:47 ET
Car Amplifier from PC Power Supply killerzracing712006-07-20  13:39 ET
Question bout Audiobahn Amps.....EseEsai10 2006-07-20  12:49 ET
Autotek amps who got em n leave a review killerzracing712006-07-20  10:48 ET
Worth it?CadillacDb23 2006-07-20  06:05 ET
Is this a reliable source to get an amp???CadillacDb11 2006-07-20  03:00 ET
RE 6.5 components...blaine westropp2006-07-20  02:07 ET
When do you know you need a HO alternator?blaine westropp2006-07-20  02:00 ET
SMELLctmike2006-07-20  00:50 ET
Amp ground wirestephen luttrell2006-07-20  00:07 ET
Good ampBigjay2006-07-19  22:49 ET
Would this work???LA2006-07-19  22:42 ET
Whats a good match for.....Jexx2006-07-19  21:38 ET
Help with Amp & Speakers PLeaseJexx2006-07-19  21:36 ET
Refurbished...Jason Flournoy11 2006-07-19  21:24 ET
The higher the signal to noise ratio the better correct????Optidriven2006-07-19  17:58 ET
MA Audio HK401SXNate So2006-07-19  17:53 ET
Some advise on amps pleaseKevin Holden2006-07-19  17:25 ET
700-900 watts at 2 ohms under $300?Steven Norris18 2006-07-19  17:05 ET
Rockford Fosgate X7.ACadillacDb2006-07-19  02:42 ET
460 mach Timothy Hollomon2006-07-18  22:38 ET
Anyone selling anything ?Jexx2006-07-18  21:42 ET
Using a 4 channel amp to power a DVC 4 ohm Sub.Troy Stafford2006-07-18  20:20 ET
Amp for components...Andrew2006-07-18  18:32 ET
Coustic 241se for sale!!!!!!!!!!Trevor Meyers2006-07-18  18:18 ET
Audison amp 2 amps for 800$ Brandon2006-07-18  17:01 ET
Ultra Linear Amps????.....Trevor Meyers2006-07-18  16:21 ET
How muchChauncey Brown2006-07-18  15:24 ET
How muchbrad lowrance2006-07-18  15:18 ET
Amp for two alpine type R 6x9'smat dope2006-07-18  12:09 ET
Hifonics brutus series[...Rovin...]2006-07-18  10:49 ET
Amp Power WiringBrandon Patton13 2006-07-18  09:30 ET
Fuses................???Optidriven18 2006-07-18  09:21 ET
Just got 2 questions!!!!CadillacDb29 2006-07-18  04:55 ET
120 Ampere Alternator ?Da Wa2006-07-18  03:46 ET
Amps placingDonato11 2006-07-18  03:41 ET
Amp for two alpine type R 6x9'shomercleeze2006-07-18  02:57 ET
Help meSteven Norris18 2006-07-18  02:36 ET
NIC CLEAN-UP!!bassman32006-07-18  02:26 ET
Just got 2 questions!!!!Steven Norris2006-07-18  02:25 ET
Need help adjusting amp for RockSteven Norris2006-07-18  02:02 ET
OT: Chauncey WHO?Steven Norris2006-07-18  01:52 ET
Will this setup work with the amp?Steven Norris2006-07-18  01:29 ET
Car amp troublebassman320 2006-07-18  00:48 ET
Ground Wire Up?Poremski2006-07-18  00:25 ET
Mark Antony AmplifiersChauncey Drinon10 2006-07-17  23:49 ET
Amp & Box for RE XXX 15"LostRookie14 2006-07-17  22:16 ET
500/1 vs. SX 650.1––––•2006-07-17  21:20 ET
Trouble hooking up 2 amp'sbassman312 2006-07-17  20:42 ET
400 Dollars - EbayMr. Bojangles10 2006-07-17  20:37 ET
Blown fusesstephen luttrell17 2006-07-17  20:35 ET
Closed Closed: New threads not accepted on this page
Home > Message Board > Car Audio > Amplifiers > Archive through July 23, 2006 [ « Previous ] [ Next » ]
