Thread: Need advice on distortion |
New member Username: Fran33
Post Number: 1 Registered: Jul-06
| Posted on Saturday, July 29, 2006 - 04:24 pm: |
Alright I have a sony CD playr thats fairly new was on sale for 200$ and 2 rear pioner speackers that i got at wall mart for about 99$, 220 wats...and two 12 inch subs in my trunk that have a dule channel amp 340 wats running to them,the wire can handle i think....it was 400 watts, i hear lots of distortion from the speackers after i hit about....25-27 out of 39 of the volume, how can i get it to reach full with out distortion, do i need an amp on the speckers too? And what type of speackers do u recomend me to buy if i need new ones....o and i have no room in the front of my car for speackers cuz its an old 1979 malibu classic lol, thanks. |
Silver Member Username: Adddisorder
West palm,
Florida
Post Number: 520 Registered: Jan-06
| Posted on Saturday, July 29, 2006 - 06:25 pm: |
ok you never want to turn your head unit up past 3/4 because in an easy way to understand blow your speakers. if it is your speakers that are distorting then yes an amp will help maybe something that does 75rmsx2@4ohm if your willing to do some work and depending on your budget you get make speakers fit in your doors or buy/make custom kick pannels to hold some 6.5 components |
