Thread: Need Opinions very important!!! |
Bronze Member Username: Justababyboy
Philly,
PA
Post Number: 78 Registered: Jun-05
| Posted on Friday, July 28, 2006 - 06:19 pm: |
Ok I ordered the diamond audio m391 6x9's and I got the diamond audio 6 inch comp set CM361 set....by mistake....i currently have a infiniy 50.7cs installed in my car.....do you guys think i should keep these diamond audio comps or send them back for my 6x9's i ordered or should I keep them and install them and sell the infinity's.....how are these diamond audio comps....i know there a later model....are they better then my infinity's Urgent need to know soon!!! |
Silver Member Username: Adddisorder
West palm,
Florida
Post Number: 508 Registered: Jan-06
| Posted on Friday, July 28, 2006 - 11:21 pm: |
i would say they are better then the infinitys because i dont really like the way they sound and DA is a repuatable brand. why you getting six by nines anyway. your better off getting a sub and it wouldnt cost much more and it would give you better low end |
Philly,
PA
Post Number: 79 Registered: Jun-05
| Posted on Saturday, July 29, 2006 - 03:20 am: |
i alrdy have a sub i just wanted rear fill for my passengers |
West palm,
Florida
Post Number: 511 Registered: Jan-06
| Posted on Saturday, July 29, 2006 - 11:38 am: |
try putting the infinitys in the back and the DA's up front there isnt much point in getting six by nines unless you arnt giong to have a sub |
Philly,
PA
Post Number: 80 Registered: Jun-05
| Posted on Monday, July 31, 2006 - 10:39 am: |
I just want my intial question answered...1. whether or not to replace the current infinity set-up with the diamond cm361's 2. whether or not the daimond cm361's are a good component system or not...thank you for your help |
Philly,
PA
Post Number: 81 Registered: Jun-05
| Posted on Tuesday, August 01, 2006 - 08:15 am: |
bump! |
Philly,
PA
Post Number: 82 Registered: Jun-05
| Posted on Wednesday, August 02, 2006 - 10:27 am: |
bump!!! |
Gold Member Username: Illuminator
Post Number: 3797 Registered: Apr-05
| Posted on Thursday, August 03, 2006 - 12:32 am: |
Keep the kappas. |
