Home > Message Board > Car Audio > Speakers > Archive through August 13, 2006 > What Good Component speakers are out ...
Author Thread: What Good Component speakers are out there for bmw
Username: Flyboyy
what component speakers should i use for a 2003 bmw 5 series with stock amp. and would make a big difference in sound quality.
Username: Illuminator
Post Number: 3646
What size speakers are they and what kind of depth do you have? It would make a massive diffrence in sound quality if it was done right. A PPI PC250 would be a great way to add some nice amplification as well.
Username: Flyboyy
i know that it uses 5.25 , i was thinkin about getting MB Quart rce213 but im worry that after i swap out the old speaker and put new one, my windows have a problem closing, because im not sure of the depth, do you know where and who i can ask to see if this speaker will fit into my door without any adjustments ? I already went to crutchfield.com and checked but they dont have much into all that was said is my car uses 5.25 speakers and that the mb quart fits.
Username: Alteraudiousa
Concord
Post Number: 1099
does it have the I-Drive on it...can't remember if it was in those cars or 04 but most shops won't touch them due to warranty and reliability.
Username: Flyboyy
Post Number: 11
no i-drive , I have the older bmw 2003. I recently installed an amp and subwoofer and kept my factory amp for my component speakers, but it seem like all my bass is stuck in the trunk anyway i can get the bass into the cabinet ? , Will changing my stock speakers do anything ? without taking out the factory amp ? any recommendations pls.
Home > Message Board > Car Audio > Speakers > Archive through August 13, 2006 > What Good Component speakers are out ... [ « Previous ] [ Next » ]
