Thread: Need cheap, but good speakers!!! |
Bronze Member Username: Nvmyboom
Post Number: 40 Registered: Jul-06
| Posted on Thursday, July 20, 2006 - 10:56 pm: |
I need help finding cheap, but also good quality speakers for my Ford Explorer. |
Silver Member Username: Adddisorder
West palm,
Florida
Post Number: 451 Registered: Jan-06
| Posted on Thursday, July 20, 2006 - 11:06 pm: |
BUDGET!? |
Silver Member Username: Kaerfpl
Spencerport,
NY
Post Number: 320 Registered: Jun-06
| Posted on Thursday, July 20, 2006 - 11:56 pm: |
^^^lol, The most asked question on this site. Also what sizes are you looking for? |
Gold Member Username: Tjmutlow
Post Number: 2646 Registered: Sep-05
| Posted on Friday, July 21, 2006 - 10:32 am: |
infinity reference |
Post Number: 44 Registered: Jul-06
| Posted on Friday, July 21, 2006 - 09:26 pm: |
All four are 6x8's. Somethin under 100 would be nice. They need to be cheap, but reliable. |
Post Number: 45 Registered: Jul-06
| Posted on Friday, July 21, 2006 - 10:20 pm: |
ok, i think i will get the 6x8's for 55 a pair at wal-mart. |
Spencerport,
NY
Post Number: 338 Registered: Jun-06
| Posted on Saturday, July 22, 2006 - 01:14 am: |
Wal-Mart? Are you crazy? Don't buy any audio equipment there. Here's something better! Alpine: http://www.sonicelectronix.com/item_42.html http://www.sonicelectronix.com/item_3453.html Infinity: http://www.sonicelectronix.com/item_6153.html http://www.sonicelectronix.com/item_4278.html Kicker: http://www.sonicelectronix.com/item_3568.html Pioneer: http://www.sonicelectronix.com/item_6379.html http://www.sonicelectronix.com/item_4311.html There, all under $100, except for the second link with the infinity speakers. There just shy over $100. |
New member Username: Chilipeps018
Post Number: 1 Registered: Jul-06
| Posted on Sunday, July 23, 2006 - 01:52 am: |
Of those above speakers which ones do you recommend best? |
Spencerport,
NY
Post Number: 339 Registered: Jun-06
| Posted on Sunday, July 23, 2006 - 02:25 pm: |
If your just mainly looking for high's, then i'd go with Pioneer. If you want something that pounds, i'd go with the Alpine Type R speakers. |
Post Number: 50 Registered: Jul-06
| Posted on Tuesday, July 25, 2006 - 08:30 pm: |
Ok, thanks alot |
