Home > Message Board > Car Audio > Multimedia Systems > Archive through July 23, 2006 > Pioneer AVIC-D2 parking brake bypass ...
Author Thread: Pioneer AVIC-D2 parking brake bypass (No Soldiering Required)
Username: Yazidneely
In order to watch the AV source in the AVIC-D2 or to have all the NAVI function while driving you must do the following:
1. Ground the original parking wire (Must Do)
2. There will be a open pin in the wiring harness under the ground wire. You must also ground this pin. I just pulled the wire out from the cellular mute pin and stuck it in the new pin and grounded it.
***This does work! No soldiering necessary. I just installed it into my car!****
Username: Illuminator
Post Number: 3471
Good info.
Home > Message Board > Car Audio > Multimedia Systems > Archive through July 23, 2006 > Pioneer AVIC-D2 parking brake bypass ... [ « Previous ] [ Next » ]
