Home > Message Board > Car Audio > Speakers > Archive through August 13, 2006 > 2 ohm Speaker Setup
Author Thread: 2 ohm Speaker Setup
Username: Claytonk
Carlsbad, CA
I recently bought one 2 channel kenwood amp rated at:
150 Watts x 2 Channels @ 4 Ohms
230 Watts x 2 Channels @ 2 Ohms
I also purchased:
one set of 6.5in. infinity components rated at 90 watts rms at 2 ohms;
one set of 4x6in. infinitys at 75watts rms at 2ohms also.
what would be the best wiring configuration that would most effeciantly drive my speakers? thank you
Username: Alteraudiousa
Concord
Post Number: 1069
run only the components off the amp and run the 4x6 off the HU.
Username: Claytonk
Carlsbad, CA
thanks ill try that
Username: Killswitchjd
Post Number: 260
dont do that... 230 wrms is too much for 90 rms speakers...
Username: Claytonk
Carlsbad, CA
what 4 channel amp would you recommend?
Home > Message Board > Car Audio > Speakers > Archive through August 13, 2006 > 2 ohm Speaker Setup [ « Previous ] [ Next » ]
