Thread: Infinity setup |
New member Username: Jimsmith
Post Number: 1 Registered: Jul-06
| Posted on Sunday, July 16, 2006 - 12:25 pm: |
I have a honda accord coupe 2006 and I want to upgrade the speakers, but I don't need to much bass. Here's what I am thinking, open to suggestions: front: infinity perfects 6.1 rear: infinity 692.7i amp: What should I get to power these? What do you think |
Silver Member Username: Believe
Illinois
Post Number: 167 Registered: Jun-05
| Posted on Wednesday, July 19, 2006 - 11:49 am: |
you need to decide if you want a 2 channel amp under the passenger seat and a 2 channel amp in the trunk.. or just one 4 channel in the trunk |
Silver Member Username: Kaerfpl
Spencerport,
NY
Post Number: 292 Registered: Jun-06
| Posted on Wednesday, July 19, 2006 - 01:03 pm: |
If you were going to go with a 4-channel amp, i'd go with this: http://www.sonicelectronix.com/item_2077.html If you were gonna do two 2-channel amps, then i'd go with these: For Infinity Perfects 6.1: http://www.sonicelectronix.com/item_66.html http://www.sonicelectronix.com/item_6725.html For Infinity 682.7i: http://www.sonicelectronix.com/item_5423.html |
Gold Member Username: Illuminator
Post Number: 3469 Registered: Apr-05
| Posted on Wednesday, July 19, 2006 - 09:16 pm: |
I'd rather get a PPI art A600.2 or PC2150. The Infinitys would sound incredible. |
