Home > Message Board > Car Audio > EQs and Crossovers > Engine noise in my c6 vette
Author Thread: Engine noise in my c6 vette
Username: Ogduncan
Post Number: 64
I have a engine noise running through my stereo. It seems to be comming from my crossover/eq that i purchased. when i turn the volume up on the deck the engine noise stays the same but when i turn it up using the eg/crossover it increases. Does anyone know how to get rid of this. I was thinking battery grounding kit or msd 8.5 spark plug wires any suggestions
Relevant Product Info
Username: Silvermopar
Nebraska
Post Number: 18
descripe the noise, i think it is feedback from your alternator.
Username: Glasswolf
Wisteria, Lane
Post Number: 11564
vettes are fun. unibody with fiberglass shell. hard to get a god ground.
run a ground wire from the battery negative terminal.
use it to directly ground your head unit, EQ, and amplifiers, etc..
avoid getting the audio wirig near any crossovers, or ignition system components.
Username: Glasswolf
Wisteria, Lane
Post Number: 11565
zac is right in that it's alternator or ignition noise, but the problem is generally caused by grounding issues.
Username: Ogduncan
Post Number: 67
as i rev the car the noise gets higher pitched. it goes with the rpm
Username: Riskyb
Post Number: 93
You may just have to turn the gain down on your amp a little bit.
Username: Ogduncan
Post Number: 68
the sound is not comming from my amps i have 3 of them and the gain is all the way down on the amp that runs the tweeters.
Username: Illuminator
Post Number: 4256
Did you read Glasswolf's advice?
Having a fiberglass unibody is no fun! Can easily cause electrical fires and whatnot.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > EQs and Crossovers > Engine noise in my c6 vette [ « Previous ] [ Next » ]
