Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > HO alt, do i need one?
Author Thread: HO alt, do i need one?
Username: Gangstafert
Jacksonville, Florida
Post Number: 239
I am going to be runing 2 arsenal 12's with a autotek mm1400.1 amp, eventually i will have another amp for components but for now do i need an HO alt?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1108
for now, i think you might need it, do you know the amperes of your stock alt?
Post Number: 240
no but its a 96 cutlass supreme???
Post Number: 242
Username: Rovin
Trinidad & T...
Post Number: 8366
i think u shoul def get 1 cause of that amt of power
http://www.wickedcases.com/caraudio/charging.html
Post Number: 243
If i get a HO alt i want to get one big enough for both the amps the next amp i will be getting will be probably a 400wrms 2channel so how big of an alt should i get?
Post Number: 244
also can someone give me a quick explanation of the big3 upgrade, and what wires i will have to buy?
Post Number: 246
also could someone give me a quick explanation of the big3 upgrade and what wires in such i will have to buy?
Username: Rovin
Trinidad & T...
Post Number: 8367
whoever is building ur ho let them know what power u intend 2 push & they will advise u accordingly
look @ the acccessories section of this forum - u will see many threads on 'big 3'........
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1117
www.bcae1.com read about wires and upgrades. I think 200A or lil more with some yellow top will do the job
Post Number: 247
I will need a yellow top?
Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > HO alt, do i need one? [ « Previous ] [ Next » ]
