Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > Kicker with crossfire
Author Thread: Kicker with crossfire
Username: Jeremiasjas
Punto Fijo, Falcon
Venezuela
Post Number: 7
can i use a sub kicker CVR15 2-ohm with an amp Crossfire CFA602 Amplifier 300w x 2. 600w @ 4 ohms bridged? if yes, what is the correct way to wire them?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1111
yeah you can use it, wire it in series
Punto Fijo, Falcon
Venezuela
Post Number: 9
thanks julio, but i want to be sure in something: the amp is two channel and the sub is dual, do i have to connect using bridge? or 1 channel per voice coil? regards
Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > Kicker with crossfire [ « Previous ] [ Next » ]
