Thread: Car stereo direct to 12v battery |
New member Username: Peter_h
Post Number: 2 Registered: Jul-06
| Posted on Wednesday, July 05, 2006 - 08:13 am: |
hi I need a little guidance I intend to wire a car amp directly to a 12v battery, but not in a car. Im not sure what to do with the ground wire since i dont have a car body to attach to, though somebody explained that i could emulate one by sandwiching aluminium and copper plates with the ground wire between. Also, what do i do with the negative connection on the battery. Can I connect the ground wire to the negative on the battery? thanks |
Gold Member Username: Illuminator
Post Number: 3326 Registered: Apr-05
| Posted on Wednesday, July 05, 2006 - 09:44 am: |
Eh, didn't see this. I responded to it in the Bragging Area of all places. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1103 Registered: Dec-05
| Posted on Wednesday, July 05, 2006 - 10:42 am: |
you can create a false ground |
