Thread: Parallel or series wire my 15" dvc sub |
Bronze Member Username: Plyrdlf42
Post Number: 14 Registered: Jun-06
| Posted on Wednesday, July 05, 2006 - 02:22 am: |
i have 1 15" dvc eclipse sub. do i wire parallel or series to amp? |
Silver Member Username: Rick_ross
Post Number: 230 Registered: May-06
| Posted on Wednesday, July 05, 2006 - 02:59 am: |
what the hell u dont even say is it 2 ohm or 4 ohm and what the specs are of the sub and the amp |
Post Number: 15 Registered: Jun-06
| Posted on Wednesday, July 05, 2006 - 03:06 am: |
excuss me ,,,,,, dont you think if i knew what i was doing i woundnt ask? dic*head |
Gold Member Username: Tjmutlow
Post Number: 2555 Registered: Sep-05
| Posted on Wednesday, July 05, 2006 - 04:31 am: |
if it is just 1 sub and it is a 2 channel amp, then most likely your going to have a problem unles the sub is a dual 2 ohm speaker |
Post Number: 16 Registered: Jun-06
| Posted on Wednesday, July 05, 2006 - 05:01 am: |
88150Ti eclipse sub dont have specs on sub.2 channel kenwood 600 amp. and like rick ross pointed out i dont know sh*t!because my speaker came with no papers, just a box,so any help would be helpful. instead of pointing out that i dont know sh*t! ive tried pulling up specs on speaker but no luck. |
Post Number: 2559 Registered: Sep-05
| Posted on Wednesday, July 05, 2006 - 08:44 am: |
i posted those specs somehwere else on your post, dual 4, 750rms, and 1500pk. that amp is not enough. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1104 Registered: Dec-05
| Posted on Wednesday, July 05, 2006 - 10:44 am: |
get audiobahn a 8000t and wire it parallel mode. |
