Thread: Pg amp |
Bronze Member Username: Jamo
Post Number: 28 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 07:20 pm: |
will this work on those 3 audiobahns PHOENIX GOLD OCTANE R15.0:1 1500W MONO AMPLIFIER |
Post Number: 29 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 07:22 pm: |
or would this be better NEW VOLFENHAG MONO 1800-W AMP CLASS-D ZX-MONOBLOCK neon |
Gold Member Username: Tjmutlow
Post Number: 2536 Registered: Sep-05
| Posted on Tuesday, July 04, 2006 - 07:23 pm: |
yes, it is 2 ohm stable.... |
Post Number: 2537 Registered: Sep-05
the pg is better |
Post Number: 30 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 07:26 pm: |
KENWOOD EXCELON KAC-X812D 1600 WATT MONO AMPLIFIER 2006 will any out of these 3 work?????????? |
Silver Member Username: Ctmike
Ct.
Post Number: 946 Registered: Feb-06
mike, stop making new threads, this is the 3rd thread for the same question in half an hour. |
Post Number: 2542 Registered: Sep-05
| Posted on Tuesday, July 04, 2006 - 07:29 pm: |
again another garbage amp..... |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1101 Registered: Dec-05
| Posted on Tuesday, July 04, 2006 - 07:36 pm: |
it doesn't matter too much if they're two ohm stable, the difference is the amount of power cuz the impedance is 2.67, YOU NEED A 1700W RMS AT 2 OHM AMP! |
Post Number: 2544 Registered: Sep-05
| Posted on Tuesday, July 04, 2006 - 07:39 pm: |
yes it does, you do not want a 1ohm stable amp, the power needs to0 be closet to max at 2 ohms..... not 1 ohm. |
