Thread: Will these have enough power??????????? |
Bronze Member Username: Jamo
Post Number: 27 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 06:51 pm: |
will this amp CRUNCH GP1600.1 1600w MONO CAR AMPLIFIER w/ DIGITAL LCD power 3 12" audiobahn AW1251SE that are 400 watts rms each are dual 4 Ohm and 2 or 8 Ohm operation |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1091 Registered: Dec-05
| Posted on Tuesday, July 04, 2006 - 06:54 pm: |
no man, you need an amp two ohm stable, that puts out 1700w rms at 2 ohm |
Gold Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 2011 Registered: Oct-05
dude. stop postin the same question with diff amps. just make one big thread. and no, i woudlnt get the crunch or the profile one that you listed before |
Tigard,
Or
U.S.
Post Number: 2012 Registered: Oct-05
| Posted on Tuesday, July 04, 2006 - 06:56 pm: |
i mean the volfenhag one. |
Tigard,
Or
U.S.
Post Number: 2013 Registered: Oct-05
| Posted on Tuesday, July 04, 2006 - 06:57 pm: |
TRY A XENON 1200.1 (1-4 OHM operation) |
Gold Member Username: Tjmutlow
Post Number: 2541 Registered: Sep-05
| Posted on Tuesday, July 04, 2006 - 07:28 pm: |
again same question, getting old, all the amps your trying to use is garbage..... |
