Thread: Will either of these make the subs pound? |
Bronze Member Username: Jamo
Post Number: 22 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 06:28 pm: |
Phoenix Gold R5.0:1 MonoBlock Amp Car Mono Amplifier ! Volfenhag 1Ch 1850 Watt Digital Car Audio Amplifie this work for 3 12" audiobahn AW1251SE that are 400 watts rms each are dual 4 Ohm and 2 or 8 Ohm operation |
Silver Member Username: Ctmike
Ct.
Post Number: 940 Registered: Feb-06
| Posted on Tuesday, July 04, 2006 - 06:32 pm: |
you planning on one pg amp for each sub, if so then it would work. don't know the specs for the other one. |
Post Number: 24 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 06:45 pm: |
no i am askin if either of those amps will work for those subs |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1092 Registered: Dec-05
| Posted on Tuesday, July 04, 2006 - 06:55 pm: |
no, try pg xenon 1200.1 |
Gold Member Username: Tjmutlow
Post Number: 2540 Registered: Sep-05
| Posted on Tuesday, July 04, 2006 - 07:27 pm: |
stop with this same question, getting very old.... |
