Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > I have 2 solobaric s10L5 ,what amp sh...
Author Thread: I have 2 solobaric s10L5 ,what amp should i use
Username: Ford_focus
Syracuse, Ny
Usa
i want to het the kx1200.1
1ohm 1200
4ohm 300
the specs on the subs are
450rms
900peak
Username: Dustin3
Tigard, Or
U.S.
Post Number: 2010
so you have (2) l5's which are 450 rms each = 900 watt amp. kicker 1200.1 would be fine if the subs are DVC 4 ohm subs ---- then wired to 1 ohm
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1093
kx is fine, i think they might overpower those l5, why don't you try hifonics 1206d. The kicker is great but you'll need to control the gain
Syracuse, Ny
Usa
well i want to stick with a kicker amp.is a hifonics amp any good.is there anything else out there
Username: Ctmike
Ct.
Post Number: 947
plenty amps out there, whats yours budget?
Username: Tjmutlow
Post Number: 2543
the jbl 1200.1, memphis 1000d,
Username: Troy81
Tavernier, Fl
Us
Post Number: 507
memphis, but dont get it stolen
Syracuse, Ny
Usa
i dont want to spend more than $400 maybe $500.is there a kicker amp that will work.if not ill try something else
Username: Tjmutlow
Post Number: 2546
the SX 1250.1 the new product for 06 that is 1 ohm stable...
Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > I have 2 solobaric s10L5 ,what amp sh... [ « Previous ] [ Next » ]
