Thread: Help! what's a good amp with around 300W x 1 at 2 ohms |
New member Username: Ekul
Post Number: 6 Registered: Jul-06
| Posted on Tuesday, July 04, 2006 - 06:11 pm: |
i'm buying infitity referecnce 12'' and lookin for a good amp. i could get an mtx but with only 250W RMS, do i really want to underpower it? Details: » 12" subwoofer with dual 4-ohm voice coils » polypropylene woofer cone with large-roll rubber surround » innovative basket design » progressive spider improves control during extreme cone movement » frequency response: 23-400 Hz » power range: 60-300 watts RMS (150 watts per voice coil) » peak power: 1200 watts » sensitivity: 93 dB |
Post Number: 7 Registered: Jul-06
| Posted on Tuesday, July 04, 2006 - 06:25 pm: |
would this be a decent amp to go with em? http://www.crutchfield.com/S-0qZtUd7xWh6/cgi-bin/Prodview.asp?readmore=true&g=12 0&I=489AP1000M#Tab |
Gold Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 2014 Registered: Oct-05
| Posted on Tuesday, July 04, 2006 - 06:59 pm: |
no. profile isnt very good wuts the rms on that sub? 300? because putting 250 into it wouldnt underpower it really |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1094 Registered: Dec-05
| Posted on Tuesday, July 04, 2006 - 07:00 pm: |
nice amp for the budget. |
Tigard,
Or
U.S.
Post Number: 2015 Registered: Oct-05
http://cgi.ebay.com/Kicker-ZX400-1-ZX-MONO-Block-CLASS-D-AMP-400W-NEW-06_W0QQite mZ130002417988QQihZ003QQcategoryZ79829QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Tigard,
Or
U.S.
Post Number: 2017 Registered: Oct-05
| Posted on Tuesday, July 04, 2006 - 07:02 pm: |
http://cgi.ebay.com/ebaymotors/NEW-PHOENIX-GOLD-XENON-400-1-400W-CAR-SUB-AMPLIFI ER-AMP_W0QQcmdZViewItemQQcategoryZ38638QQihZ008QQitemZ180001776447QQrdZ1 or http://cgi.ebay.com/ALPINE-MRP-M350-700w-CAR-STEREO-MONO-AMPLIFIER-SUB-AMP_W0QQi temZ170001794515QQihZ007QQcategoryZ79825QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Tigard,
Or
U.S.
Post Number: 2018 Registered: Oct-05
| Posted on Tuesday, July 04, 2006 - 07:03 pm: |
those are some nice amps. the profile is like juliob said, a ok budget amp. |
Silver Member Username: Ctmike
Ct.
Post Number: 942 Registered: Feb-06
take the xenon |
Post Number: 1097 Registered: Dec-05
| Posted on Tuesday, July 04, 2006 - 07:06 pm: |
bassman, the profile is nice, 500x1 at 2 ohms, it will put at least 300w, don't you think. They're a good budget brand, you can't get better for the price. Go for it Luke, infinity doesn't needs a lot of power to pound. |
Post Number: 1098 Registered: Dec-05
| Posted on Tuesday, July 04, 2006 - 07:08 pm: |
PG is the best for the job. |
Ct.
Post Number: 944 Registered: Feb-06
| Posted on Tuesday, July 04, 2006 - 07:10 pm: |
luke, if you interested in the pg i have a couple i'm selling so depending on were you live i could do that price, maybe better. i just wont go to low, love those amps |
Gold Member Username: Tjmutlow
Post Number: 2538 Registered: Sep-05
| Posted on Tuesday, July 04, 2006 - 07:24 pm: |
kicker zx-350.1 |
Post Number: 8 Registered: Jul-06
| Posted on Tuesday, July 04, 2006 - 08:03 pm: |
thx for the replies! i found this also http://www.crutchfield.com/S-uYXn7WZ8oYP/cgi-bin/ProdView.asp?g=120&I=489AP1200 another profile only it's not mono and it can put 300W RMS into each sub, exactly what they need. another one i found i think i might go with it http://www.onlinecarstereo.com/CarAudio/ProductList.aspx?CategoryID=1&Manufactur erID=650, Phoenix Gold R8.0:1, it's a mono class d, and puts out 300W RMS to each sub. i can get it for $185 from sonicelectronix, is that a decent one? looks like it's gotten good reviews, i don't want to go over $200 for the amp tho. |
Post Number: 9 Registered: Jul-06
| Posted on Tuesday, July 04, 2006 - 08:11 pm: |
that xenon is sweet, only would put out 200W RMS tho compared to the 300 for Pheonix R8, the xenon 600 puts out 300W but it's more money. thx bassman for postin those ebay links. and ctmike i live in SD lol, what PG's do u have? |
Tigard,
Or
U.S.
Post Number: 2022 Registered: Oct-05
| Posted on Tuesday, July 04, 2006 - 08:28 pm: |
no problem. the PG 400.1 would be the best bet. and its $ 150. really good price |
Post Number: 10 Registered: Jul-06
| Posted on Tuesday, July 04, 2006 - 09:01 pm: |
AHHHHHH, that PG R8 is over 200 i forgot the s & h. i've been researchin this stuff for days and i wanna get it ordered in the next couple of hrs. i found the PG 600 on ebay for 200. and you gave me the link with the 400 for 150 but then i look at all those negatives the seller has lol, how do u kno if those aren't refurbished :S. and they don't come with a warranty like other sites >.< gah my brain is gonna explode. ok i wanna get one of those PG's but it'll prolly have to be off ebay. so should i take a chance with ebay or go with a profile that has a 3 yr warranty, what's ur guys experience with those powersellers that have like 500 negative feedback. |
Bronze Member Username: Tdawg30
Ohio
Post Number: 49 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 09:09 pm: |
get on ebay if u can buy from there and look at the profile amps online. they are tons cheaper. and the one store offering them gives u a 6 month warranty. |
Silver Member Username: N2audio
Lawrence,
Ks
Post Number: 904 Registered: Mar-04
| Posted on Wednesday, July 05, 2006 - 12:14 am: |
Profile makes a solid amp for the price. Defects aren't that common, and according to a few tests I've seen they come within about 20% of rated power - 500w amps tend to test around 400. Check out the prices at millionbuy.com. The ap1200, for example is $109 plus shipping, should be about $125 shipped, but for what you want you'd probably be better of with the ap1000m. $100 plus shipping and should give you 400w+ at 2 ohms |
