Thread: This amp Work?? |
Bronze Member Username: Jamo
Post Number: 20 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 01:09 pm: |
will the Kenwood KAC-9102D Mono Car Amplifier Class D 1700 Watts work for 3 12" audiobahn AW1251SE that are 400 watts rms each are dual 4 Ohm and 2 or 8 Ohm operation |
Gold Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 2002 Registered: Oct-05
| Posted on Tuesday, July 04, 2006 - 01:32 pm: |
that amp does 850 watts x 1 at 2 ohms bridged... you would be lucky to get 150-200 watts to each sub. so no, it wouldnt work |
Bronze Member Username: Tdawg30
Ohio
Post Number: 46 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 01:39 pm: |
yeah plus the features on it arent so great. the controls are hard to get to and its just a pain in the @ss. thats why i sold mine. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1072 Registered: Dec-05
| Posted on Tuesday, July 04, 2006 - 02:35 pm: |
you should try getting an amp that does 1700w at 2 ohms, orion 2500d or check some kicker models |
Gold Member Username: Tjmutlow
Post Number: 2529 Registered: Sep-05
| Posted on Tuesday, July 04, 2006 - 05:04 pm: |
need an amp that does max at 2 ohms, like if need cheap the audionbahn a16000v like @250 delivered... |
