Thread: Amp Match for 2 2ohm type R's |
New member Username: Twinkles5
Post Number: 3 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 09:44 am: |
I have these subs with the Kenwood 9102-D and I want to upgrade my amp to something more powerful. I looked around in Crutchfeild and found the Infinity Reference 1211a. Is that amp suitable, or should I look around some more? And if so then what? Thanks. |
New member Username: Railrocker
Marysville,
KS
United States
Post Number: 9 Registered: Jul-06
| Posted on Tuesday, July 04, 2006 - 12:27 pm: |
dont buy anything from crutchfeild they are very very overpriced. Look around! Whats your budget? |
Post Number: 4 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 01:13 pm: |
I know to look around, but that's where I found it. Is it a good amp? My limit is probably 500-600 dollars. |
Gold Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 2001 Registered: Oct-05
| Posted on Tuesday, July 04, 2006 - 01:29 pm: |
buy on ebay... yes. for (2) 2 ohm type r's, thats a good amp. i have always had some questions about infinity amps but some people have never had any problems with them i rather get the kicker zx1000 - if they are 12" type-r's that kicker amp would be TONS BETTER that the infinity IMO because its better quality and u wouldnt have to worry bout it crappin out on ya http://cgi.ebay.com/KICKER-ZX1000-1-ZX-1000W-CLASS-D-MONO-AMPLIFIER-NEW_W0QQitem Z120004614403QQihZ002QQcategoryZ79829QQssPageNameZWDVWQQrdZ1QQcmdZViewItem if you want more power to your subs ---- you can get 2 amps that put out 600-700 watts @ 1 ohm |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1073 Registered: Dec-05
| Posted on Tuesday, July 04, 2006 - 02:37 pm: |
i agree with bassman, try getting one amp, is less complicated. |
Post Number: 5 Registered: Jun-06
| Posted on Tuesday, July 04, 2006 - 02:53 pm: |
Thanks Guys. I'll look into them. |
