Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > Planet audio
Author Thread: Planet audio
Username: 94chevyboy
Tampa, Fl
Is planet Audio a good brand will the vx1400class d push 2 L5 kicker 15's
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1065
they're not the greatest thing, they're kinda budget brand, i'd only consider their HIGH END stuff, but they're considered a questionable brand. Do you have the specs of the amp?
Tampa, Fl
it suppose to be 1250 max at 1 ohms 800rms ant 1 ohm
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1081
forget about max power, that's never real. Your amp should be putting like 600w rms at 1 ohm (cuz planet audio is overrated). If those subs are dual 4 ohm you should consider buying hifonics 1606d if you're on budget. Try selling the planet audio. By the way, those subs are SPL only, no SQ at all.
Username: Tjmutlow
Post Number: 2532
Boss Audio high end line
Username: Illuminator
Post Number: 3313
Yep, back in the day Planet Audio was awesome.
Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > Planet audio [ « Previous ] [ Next » ]
