Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > WHAT AMP? IM NEW
Author Thread: WHAT AMP? IM NEW
Username: Stfuspaceship
can someone pls tell me a good amp to get that will run 2 12" DVC 4ohm kicker cvr's. WHat would be the best way to wire them? .And i would like to spend around 350-400 bucks on it.i just want one that wont overheat. one guy at work said a jl 500/1 but i want some more opinions. thanks for any help.
Username: Dustin3
Tigard, Or
U.S.
Post Number: 1945
the best way would be to wire them to a 1 or 4 ohm load.
amp =
mbquart raa1000
audiobahn a8002t
HIFONICS BXi1206D
just to name a couple
Thank you. I will check those out
Username: Dustin3
Tigard, Or
U.S.
Post Number: 1950
also. that jl is underpowering them. the guy at the shop knows absolutely nothin. you need AT LEAST 750-800 + RMS @ 1 or 4 ohms
the mb quart is really nice
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1054
i agree, try getting the mb quart
ok im gonna get the mb quart when i get my extra paycheck in august. what kind of box should i run them in seald?(its a ford ranger extra cab)and what size wire? THANK YOU GUYS FOR ALL THE HELP I REALY APREACIATE IT. im trying to learn all this stuff and i just get lost some times is there a book i should read?
Username: Dustin3
Tigard, Or
U.S.
Post Number: 1999
www.bcae1.com (extremely usefull site!!)
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1080
yea man, www.wickedcases.com is a nice site too. Those Cvr's should be ported.
does it matter if it is slot vented or round ports? What should they be tuned to? 2 12's can they be in one enclosure or does each sub need its own?
Username: Dustin3
Tigard, Or
U.S.
Post Number: 2033
one enclosure. doesnt matter slotted or round port, and tuned to 35
thank you
Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > WHAT AMP? IM NEW [ « Previous ] [ Next » ]
