Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > S's making a hiss with new headunit?
Author Thread: S's making a hiss with new headunit?
Username: Ruthless06
C-ville, Va
Post Number: 181
I have a Clarion DRZ9255 Headunit, JL Audio zr525cSi's, a JL 300/4 pushing those.
Using the headunit as an active crossover; has 8 channel preouts, each with high and low pass x-overs. Built in 5 band equalizer which you can chose your eq points.
My question is that nearly everytime someone in a song says an S it is kind of harsh. I have adjusted the gain on the amp, the x-over points, the polarity, the gain of each driver, the q of each driver, the eq of the head unit. pretty much every function on the amp and decks. Was wondering if anyone has seen or heard of a fix for this.
Thanks!
Scott
Username: Maxsq
Post Number: 7
What you need to do is turn down the eq in the HU around 1000 -2000 Hz. That is the first thing to do and then you need to take and put the tweeter at -1.5 and you should have the problem resolved.
Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > S's making a hiss with new headunit? [ « Previous ] [ Next » ]
