Thread: Amp wiring kit? |
Silver Member Username: Gangstafert
Jacksonville,
Florida
Post Number: 217 Registered: May-06
| Posted on Sunday, July 02, 2006 - 01:01 am: |
what kind of ampkit will i need for two arsneal 12's with a autotek mm1400.1 amp. need help fast. thanx |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 8309 Registered: Jul-05
| Posted on Sunday, July 02, 2006 - 01:15 am: |
well it depends on the distance of amps from batt use this link http://www.the12volt.com/info/recwirsz.asp i would suggest u buy 0g into a distro block with 2 fuses & out into (2) 4g wires ..... |
Jacksonville,
Florida
Post Number: 219 Registered: May-06
| Posted on Sunday, July 02, 2006 - 01:27 am: |
So could i get all that in a kit i was gonna go knukonceptz and what exactly does the distro block do and is it hard to hook up.thanx |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 1032 Registered: Dec-05
| Posted on Sunday, July 02, 2006 - 11:40 am: |
www.bcae1.com go check |
Jacksonville,
Florida
Post Number: 220 Registered: May-06
| Posted on Sunday, July 02, 2006 - 12:43 pm: |
Im sorry im a noob and all that was very confusing. Is the install Rovin suggested good and if so can i buy all of that in a kit or not?thanx. |
Jacksonville,
Florida
Post Number: 221 Registered: May-06
| Posted on Sunday, July 02, 2006 - 04:25 pm: |
Could anyone help me with this. This is my first system and i want it done right and the website givin was sortof confusing. For now i really just need to know what to buy and where to buy it from.Thanx |
Jacksonville,
Florida
Post Number: 223 Registered: May-06
| Posted on Sunday, July 02, 2006 - 07:12 pm: |
anyone please... |
Bronze Member Username: Justblaze
St.Louis,
MO
Post Number: 21 Registered: Jun-06
| Posted on Monday, July 03, 2006 - 01:33 pm: |
rovin, why would he need a dist block for one amp? |
Jacksonville,
Florida
Post Number: 228 Registered: May-06
| Posted on Monday, July 03, 2006 - 06:45 pm: |
Thats whats confusing me. I need to know what to buy???????? |
Jacksonville,
Florida
Post Number: 230 Registered: May-06
| Posted on Monday, July 03, 2006 - 09:42 pm: |
anyone??? |
Gold Member Username: Dustin3
Tigard,
Or
U.S.
Post Number: 1970 Registered: Oct-05
| Posted on Monday, July 03, 2006 - 09:46 pm: |
you dont need a distro block. rovin prolly got confused and thought you were runnin 2 amps. get a 0 awg amp installation kit. the one at knukonceptz is very very nice but its 80 bucks. |
Bronze Member Username: Kravenblood
Ohio
Post Number: 70 Registered: Aug-05
| Posted on Monday, July 03, 2006 - 09:48 pm: |
you buy a dist block just in case you get another amp you know for your components buy it now so you dont have to later.. |
Tigard,
Or
U.S.
Post Number: 1971 Registered: Oct-05
| Posted on Monday, July 03, 2006 - 09:49 pm: |
not zero. i mean 1 awg. but you can run the 4 awg wire if you want. that would work fine |
Jacksonville,
Florida
Post Number: 231 Registered: May-06
| Posted on Monday, July 03, 2006 - 09:50 pm: |
B told me to get a dist. block too dont you need one if your amp has two power terminals i really dont know they had me so confused earlier. Why is that kit from knukoncepts so expensive is there any cheaper ones? thanx. |
Tigard,
Or
U.S.
Post Number: 1972 Registered: Oct-05
| Posted on Monday, July 03, 2006 - 09:52 pm: |
for 1400 watts its rec. to use a 2 awg tho so 2 would be ur best bet but 4 if you cant get one and it doesnt matter if you buy it now or later. it doesnt take long to set up. he never even mentioned anything bout components |
Tigard,
Or
U.S.
Post Number: 1973 Registered: Oct-05
| Posted on Monday, July 03, 2006 - 09:54 pm: |
i would ask B and rovin why they said that... i'm prolly missin somthin |
Jacksonville,
Florida
Post Number: 232 Registered: May-06
| Posted on Monday, July 03, 2006 - 09:59 pm: |
So a 2 gauge amp kit would be best and run it strate through with no dist block. I dont mind buying the 0 gauge kit if thats what i need also will the kit come with a fuse or do i need to buy one? Also i baught the amp from B in that group buy and i thaught i made it clear that i was only wiring one amp and thats where i got confused... |
Tigard,
Or
U.S.
Post Number: 1974 Registered: Oct-05
| Posted on Monday, July 03, 2006 - 10:23 pm: |
like i said... i would ask B and Rovin why they said that because i dont understand why unless u were gettin another amp... 2 awg would be the best for the amp. ur fuse should be around 175- 200 MAX |
Tigard,
Or
U.S.
Post Number: 1975 Registered: Oct-05
they also know alot bout the mean machine amps |
Jacksonville,
Florida
Post Number: 233 Registered: May-06
| Posted on Monday, July 03, 2006 - 11:53 pm: |
Bassman i looked up the amp on a couple of sites and it says it has 4 gauge power connectors so maybe thats what B was saying? |
Jacksonville,
Florida
Post Number: 234 Registered: May-06
| Posted on Tuesday, July 04, 2006 - 12:22 am: |
If that is the case then would that mean the amo has two 4 gauge power connectors then i would need a dist block. Im so d@mn confused... |
Tigard,
Or
U.S.
Post Number: 1991 Registered: Oct-05
| Posted on Tuesday, July 04, 2006 - 12:24 am: |
i dunno, i think that means it can accept 4 awg wiring. i dunno tho... best bet is to ask him (B)-- why he said u need a distro block |
Tigard,
Or
U.S.
Post Number: 1992 Registered: Oct-05
maybe ask him in that other forum, the j designs one. |
Jacksonville,
Florida
Post Number: 236 Registered: May-06
| Posted on Tuesday, July 04, 2006 - 01:18 am: |
Rovin do you know anything about this? |
Tigard,
Or
U.S.
Post Number: 1997 Registered: Oct-05
| Posted on Tuesday, July 04, 2006 - 04:04 am: |
maybe make a new thread in the sub section... where he is most |
