Home > Message Board > Car Audio > Head Units > Anyone Need Wiring Help!!!! > Archive through June 09, 2006
Author Thread: Archive through June 09, 2006
Username: Spayde
Hey can someone please help me with the wiring codes for a 94' intrepid. Also I see here that you keep putting "constant 12V" and "switched 12V". Which wire from my Pioneer CD Player would I hook up to the the "constant 12V", "ACC (Red)" or "battery (Yellow)". I am also left with one wire left over... Sorry if those are stupid questions. My dash lights and tail lights are no longer working once I hooked up the CD player that is why I need help, which wire would control these, or could I have blown a fuse.
Relevant Product Info
Username: Dj_d3cib3l
Does anyone know the wiring schematic for a 1994 Honda Accord EX Sedan and a 1999 Honda CRV? Also, would I be able to buy harness adapters that plug into the OEM harness and have bare wires on the other end at a place like Auto Barn or Pep Boys? I want to keep my OEM harnesses intact, but I also need the raw end adapters by saturday and cannot wait 5+ business days for ebay sellers. Thanks!
Username: Nypdlapd
Ontario
Post Number: 434
Eric, u can get an aftermarket harness from pepboys and stores like that,BUT i don't no if they have the OEM...
Accord
A Right Rear Spkr (+) Red w/ Yellow Stripe
Left Rear Spkr (+) Blue w/ Yellow Stripe
Power Antenna Trigger Brown w/ White Stripe Blue
+12 Volt Ignition Wire Yellow w/ Red Stripe
Right Rear Spkr (-) Brown w/ White Stripe
Left Rear Spkr (-) Gray w/ White Stripe
Ground Wire Black
+12 Volt Battery Wire White w/ Yellow
Left Front Spkr (+) Blue w/ Green Stripe
Right Front Spkr (+) Red w/ Green Stripe
Left Front Spkr (-) Gray w/ Black Stripe
Right Front Spkr (-) Brown w/ Black Stripe
CRV::
Constant 12V+ White/Blue
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer Red
Front Speakers
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Username: Nypdlapd
Ontario
Post Number: 435
Doug you would hook up the constant to the YELLOW wire,and switched to the RED
Right Rear Spkr (-) Blue w/ White Stripe
Left Rear Spkr (-) Brown w/ Yellow Stripe
Right Front Spkr (+) Purple
Left Front Spkr (+) Dark Green
Right Rear Spkr (+) Blue w/ Orange Stripe
Left Rear Spkr (+) Brown w/ Blue Stripe
Power Antenna/Amp White (use for Infinity Radio)
+12 Volt Battery Wire Pink or Pink w/ White Stripe
+12 Volt Ignition Wire Red w/ White Strip
Right Front Spkr (-) Blue w/ Red Stripe
Left Front Spkr (-) Brown w/ Red Stripe
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Black
Username: Spayde
Thanks a lot, but I also have an orange wire coming from the car, that I have no use for. Should I just tie it off? I connected the braid to the back of my CD player but the car also has a black/gold stripe cord (I believe.)should I attach that to the black ground wire from my CD Player? You've been a huge help, thanks.
Username: St4l1n
Redding, CA
Just replacing the factory deck on my 99 C280 Benz, I noticed you had a post of the '90 E series and I was wondering if that diagram also applies to my deck? Thanks!
Post Number: 8
Thanks for the wiring info. The harness I need is an aftermarket harness. I just need one that plugs into the original one and has bare wires on the other end so that I wont have to splice the wires on the original harness.
Username: Nypdlapd
Ontario
Post Number: 437
1999 Mercedes C-Class
Constant 12V+ Pink/Green
Switched 12V+ Red/Blue
Ground Brown
Illumination n/a
Dimmer Gray/Blue
Antenna Trigger Blue/White
Antenna Left Rear
Front Speakers 6 1/2" Doors
Left Front (+) Green
Left Front (-) Brown/Green
Right Front (+) Orange
Right Front (-) Brown/Orange
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Pink
Left Rear (-) Brown/Pink
Right Rear (+) White
Username: Nypdlapd
Ontario
Post Number: 438
Eric yes the aftermarket one plugs in and it has the wires spliced
Username: Thebum
how about a 1997 hodna accord lx? I need to doublecheck the installation, some of the connections are definitely wrong. I'm sorry if it was already on the page and I'm just oblivious. Thanks.
Username: Thebum
mmm, hodna audio wiring...
Username: Thebum
Yeah, that was definitely supposed to be honda
Username: Tjmutlow
Post Number: 2070
Information )
1997 Honda Accord Stereo Information
Constant 12V+ Yellow/White
Switched 12V+ White/Red
Ground Black
Dimmer n/a
Antenna Trigger Yellow/White
Antenna Left Rear
Front Speakers 5 1/4" Doors
Left Front (+) Blue/Green
• Alarm Information • Cruise Information
Username: Tjmutlow
Post Number: 2071
eric go, the harnesses are common harness for those hondas, any car auduio shop would have them...
Username: Phatty34
also whenever i turn on the dash lights the gear lights dim but no dash lights come on and then when i switch them off the gear lights light up again.
Username: Nypdlapd
Ontario
Post Number: 443
take off the dimmer wire!!!
Username: Phatty34
from the cd player? i have everything disconnected no fuses are blown to my knowledge is there any specific duse under the hood that could cause them not to work? i looked in the manual and it doesnt show any just fuses to the head lights its for a 99 isuzu rodeo
Username: Tjmutlow
Post Number: 2089
you need to take a test light, and teset every fuse(both sides of the fuses)
Username: Qslimms
Swanton, Oh
Usa
Post Number: 49
anyone gotta wiring diagram for a 99 mitsubishi diamante
Username: Zogan
i was wondering if anyone had the wireing color for a 97 Jetta it would be alot of help
Username: Thebum
thank you master mutlow
Username: Tjmutlow
Post Number: 2102
1997 Volkswagen Jetta Stereo Information
Constant 12V+ Red/White
Switched 12V+ Gray/Blue
Ground Brown
Illumination n/a
Dimmer n/a
Antenna Left Front
Left Front (+) Blue/Black
Left Front (-) Orange/Blue
Right Front (+) Red/White
Right Front (-) Orange/White
Left Rear (+) Red/Light Green
Left Rear (-) Orange/Black
Right Rear (+) Blue/Light Green
Right Rear (-) Orange/Red
Username: Koz67
New paltz, Ny
I am looking for the wiring color codes for 98 dodge stratus to figure out whats what for the radio
Username: Motonut427
could someone please show me the wiring diagram for a 1996 f-150 with the lowest sound package? It's a fleet side truck. thanks!
Username: Tate89
1998 ford escort lx
Username: Tate89
1998 ford escort lx audio wiring
Username: Girlie
1995 Ford F-150 wiring?
Username: Tjmutlow
Post Number: 2104
1998 Dodge Stratus Stereo Information
Constant 12V+ Pink/Yellow
Switched 12V+ Red/White
Ground n/a
Illumination Orange/Brown
Dimmer Black/Light Blue
Antenna Trigger Orange/Red
Antenna Right Rear
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Username: Tjmutlow
Post Number: 2105
1996 Ford F Series Stereo Information
Constant 12V+ Green/Purple
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination Light Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 6" x 8" Side Panels
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
Username: Tjmutlow
Post Number: 2106
1995 Ford F Series Stereo Information
Constant 12V+ Green/Yellow
Ground Red or Black
Illumination Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Left Front (+) Orange/Green
Left Front (-) Black/White
Right Front (+) White/Green
Right Front (-) Black/White
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
Username: Tjmutlow
Post Number: 2107
1998 Ford Escort Stereo Information
Constant 12V+ Blue/Red
Switched 12V+ Blue/Black
Ground Black
Dimmer n/a
Antenna Trigger n/a
Antenna Driver's Pillar
Left Front (+) Purple
Left Front (-) Blue/Orange
Right Front (+) Blue/White
Right Front (-) White
Rear Speakers 6" x 8" Rear Deck
Left Rear (+) White/Blue
Left Rear (-) Red/Blue
Right Rear (+) White/Green
Right Rear (-) Blue
1998 Ford Escort ZX2 Stereo Information
Ground Black
Dimmer n/a
Antenna Trigger n/a
Antenna Right Rear
Right Rear (-) Blue
Username: Girlie
Thanks Ty! What about a 1994 Maxima?
Username: Dp3069
yo i really need help with my 1990 nissan 240sx
Username: Tjmutlow
Post Number: 2109
1994 Nissan Maxima Stereo Information
Constant 12V+ Red/Black
Switched 12V+ Blue
Ground n/a
Illumination Red/Yellow
Dimmer n/a
Antenna Right Rear
Front Speakers 4" x 6" Doors
Left Front (+) Blue/White
Left Front (-) Blue/Yellow
Right Front (+) Brown
Right Front (-) Brown/White
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
Username: Tjmutlow
Post Number: 2110
1989-90 Nissan 240 SX Stereo Information
Switched 12V+ Blue
Ground Chassis
Illumination Red/Blue
Dimmer Red/Yellow
Antenna Trigger Black/Red
Antenna Left Rear
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
Username: Nelrubio007
I need help with my Toyota Cressida 1991
Username: Drift247
NY
Post Number: 11
any one have the wire code for a 91 ford escort?
Username: Wes_horses
DO YOU KNOW HOW TO RESET SECURITY CODE FOR A KENWOOD KDC-519 SO IT WILL START WORKING?
THANKS,WES
Username: Phatty34
Post Number: 7
i need help!!! i have a 1999 isuzu rodeo and the factory wiring end has been cut off i then wired it directly to the cd player as a result. i have lost dash lights since then. the fuses are all fine and no wires are touching each other how would i check the fuses with the test light and there isnt any fuse under the hood that is labeleed for interior lights. is there a inline fuse that rodeo would have put in and if so would you know where?
Username: Amcchio
need some help,I installed a new stereo in a 90 Escort and it wouldnt work so I switched back to the factory stereo and now it doesnt work either,the fuse is good,,,any suggestions?
Username: Lbrand
Can anyone help me out?
Got my hubby a CD player for his 2003 F-150 supercab. Thought I did so well, getting dash kit and harness... BUT... found out when he gets the dash all torn apart, that the guy at the store sold me the wrong harness (Scosche FD23B).
So I call Scosche, they tell me to get FDK106. Still not right. One of the plugs fits, but theres a square plug with 20 pins - lined up in rows - 7/6/7 that doesn't match up to anything.
What are we missing? What does this plug's wires hook to? I'm stumped and can't even find wiring info anywhere.
Any help you can provide is appreciated.
Username: Jeanhackman
Hi - Hope s'one can help. I am in desperate need of wiring info for an S-reg Ford Fiesta Zetec.
TIA
Username: Sport_4693
Wiring diagram for a 1991 Ford Ranger (Radio) what does all the color mean and what are they
Username: Nameddriver
i have a 1992 supra with the optional 10 speaker sound system and amp, im upgrading the original head unit to a cd player, there is no apdapter for it and i just cant make head nor tail of the wiring system, the original head unit is a fugitsu ten - 86120 - 2b320, please help.
Username: Zteb
I am looking for the Alarm wiring guide with remote start for a:
2006 Ford F-150 Lariat Crew Cab 4x4 with 5.4L
Thanks for your help!
Username: Buddha2007
Belmont, NC
US
Hey whats goin on, I need some help, im tryin to put a new radio in my 91 ford aerostar, its a Kenwood KRC-207s, and i can not figure out how to splice the wires, can anyone help me? Or can it even be done? I would appreciate any help. thnx
Buddha
Username: Tjmutlow
Post Number: 2126
1991-92 Ford Ranger Stereo Information
Ground Chassis
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Rear Speakers 5" x 7" Rear Wall
Username: Tjmutlow
Post Number: 2127
1991 Ford Aerostar Stereo Information
Ground Red or Black
Dimmer n/a
Antenna Trigger Orange/Blue
Antenna Right Front
Front Speakers 5" Dash
Rear Speakers 3 1/2" Tail Gate
Username: Tjmutlow
Post Number: 2128
03 f-150, funny casue went to scosche website and wire harness is the FD-16
Username: Tjmutlow
Post Number: 2129
1991 Toyota Cressida Stereo Information
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Right Rear
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Light Green
Right Front (-) Blue
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
Username: Tjmutlow
Post Number: 2130
1991-93 Ford Escort Stereo Information
Ground Red
Dimmer n/a
Antenna Trigger n/a
Front Speakers 5 3/4" Doors
Left Front (-) Blue/Light Green
Right Front (-) Green/Yellow
Rear Speakers 4" Side Shelves
Username: Combo65
I need the stereo color codes for a 2006 Ford Ranger.
Username: Jboyerv
