Thread: Whitch Amp Is Better Out Of These? |
Bronze Member Username: Blazerboy
Post Number: 20 Registered: Jun-06
| Posted on Wednesday, June 28, 2006 - 10:44 pm: |
Hey guys, As some of you know I just bought a pair of RF punch 12" stage 1 subs with a total RMS wattage of 600 Watts. Now I just need an amp. I have limited it down to two. Audiobahn A8000T with a 400RMS wattage shown here, http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13490 Or a Rockford Fosgate P3002 Punch amp that puts out 300 RMS shown here, http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14320 Any sugestions on witch one to get would be great. |
Silver Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 941 Registered: Dec-05
| Posted on Wednesday, June 28, 2006 - 10:48 pm: |
what's the voice coil config on your sub. If is dual 4 you should go with the bahn. |
Post Number: 942 Registered: Dec-05
| Posted on Wednesday, June 28, 2006 - 10:50 pm: |
you should get those amp from ebay, better prices |
Post Number: 23 Registered: Jun-06
| Posted on Wednesday, June 28, 2006 - 10:53 pm: |
Yea they are single voice coil, and yea I just thought I'de attach a link to them, but im sure ebay would be the way to go. |
Post Number: 25 Registered: Jun-06
| Posted on Wednesday, June 28, 2006 - 10:58 pm: |
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D9741311077%26&sspagename= STRK:MEWA:IT%26 Theres the Ebay link for the subs, it would probly help out a tad... Keep the sugestions coming. Thanks! |
Silver Member Username: Rick_ross
Post Number: 211 Registered: May-06
| Posted on Wednesday, June 28, 2006 - 11:00 pm: |
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14130 |
Silver Member Username: Camaro823
British Colu...
Post Number: 402 Registered: Jun-05
| Posted on Wednesday, June 28, 2006 - 11:19 pm: |
Arent the P1's rated at 150 watts RMS ? 300 watt Max. You should be able to find some cheaper amps on ebay that will handle that. |
Post Number: 26 Registered: Jun-06
| Posted on Wednesday, June 28, 2006 - 11:38 pm: |
150 Watts RMS 300 Watts Peak But I have a pair so Ill need something that puts out like 300-400 RMS correct? Im a noob with all this stuff so corrct me if im wrong. Also feel free to sugest any other amps that would work for the subs. |
Gold Member Username: Tjmutlow
Post Number: 2460 Registered: Sep-05
| Posted on Thursday, June 29, 2006 - 07:10 am: |
Any 2 channel is not the best move, you need a mono 2 ohm stable amp, try the kicker zx-350.1 or 400.1 |
Post Number: 27 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 07:33 am: |
ok thanks. I'll stick with the mono's. Any more sugestions, or pros or cons for any above mentioned amps? |
Bronze Member Username: Makmillion
United States
Post Number: 70 Registered: Apr-06
| Posted on Thursday, June 29, 2006 - 12:00 pm: |
Better to overpower your subs than underpower them. Besides, the specs given on a sub are general guidelines, not exact specs. They are temp. tested at the factory to be rated between 150-300.. you can easily stick them on a amp that will push 600 rms at 2 ohms and they'll last you a lifetime and sound awesome. You're more likely to blow a sub from underpowering it than overpowering it. I've very rarely seen someone bring in an overpowered sub for replacement, but more often its from putting 300 watts to a 500 watt sub for example. Get a 600 rms @ 2 ohm amp.. mono is more efficient and is ideal for subwoofers, but 2 channel will work just fine, you'll pay more for a 2 channel that will put out 300 watts x 2 rms @4 ohms than you will for a mono that twill put out 600 watts rms x 1 @ 2 ohms, however. Recommendation: 600rms @2 ohm monoblock amp. Hifonics, Eclipse, Phoenix Gold and Memphis are all awesome brands. Don't buy a audiobahn, it's a waste of space and will be a doorstop or paperweight in only a few months. Kicker is great, if you want to pay for the name. Good luck |
British Colu...
Post Number: 405 Registered: Jun-05
| Posted on Thursday, June 29, 2006 - 12:39 pm: |
PG Xenon 400.1 |
Post Number: 28 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 01:33 pm: |
OK I thought I had it figured out but now I have a lot of opinions... I have heard 300RMS all the way to 600RMS. I would liek to get the most power out of them without ruining them...What RMS do you guys suggest? Thanks! |
Post Number: 29 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 01:39 pm: |
Also could you guys please list some specific Hifonics, Eclipse, Phoenix Gold and Memphis amps that you would recomend for my subs. Again, i am very new at this so teh easier you guys make it for me the better, thanks. |
British Colu...
Post Number: 407 Registered: Jun-05
| Posted on Thursday, June 29, 2006 - 02:18 pm: |
600 is too much, aim for 300 - 400, I reccommend the the Phoenic Gold Xenon 400.1, but what is your price range ?? and are you willing to use ebay ? |
Post Number: 943 Registered: Dec-05
| Posted on Thursday, June 29, 2006 - 02:24 pm: |
the audiobahn is not a cr@p, is a nice amp. A8000t is one of the best amp for the budget. Best deal is PG xenon 400.1 or check profile if you're on a budget |
Post Number: 30 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 03:05 pm: |
I guess I would call my price range from about 80-175$ or so, and yes I am definately interested in ebay, and will most likely get teh amp of there. Keep the ideas flowing! thanks! |
Post Number: 952 Registered: Dec-05
| Posted on Thursday, June 29, 2006 - 03:36 pm: |
a8000t is the best deal on budget |
Post Number: 31 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 03:40 pm: |
Does the a8000t or PG xenon 400.1 come with a bass remote or nob? |
Post Number: 32 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 03:42 pm: |
I guess it's down to those two now... |
Post Number: 33 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 03:43 pm: |
I guess its down to those two... |
British Colu...
Post Number: 408 Registered: Jun-05
| Posted on Thursday, June 29, 2006 - 03:58 pm: |
item #280002725246 on ebay check it out I would get that and it comes with a bass remote, but remember to be careful with that, keepint it at high levels could cause damage to your subs. |
Post Number: 34 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 04:26 pm: |
What would you say a safe level would be for the bass remote? Also could you guys please help me find some Ebay listings for the a8000t or PG xenon 400.1? I looked for the a8000t but all I can find is 800W ones. thanks again... |
British Colu...
Post Number: 414 Registered: Jun-05
| Posted on Thursday, June 29, 2006 - 04:31 pm: |
Well i'm just saying not to keep it at its max for extended periods of time, I would probably keep it in the middle but I sometimes when I'm showing my friends turn everything up and get crazy loud. I'll try to find you some on ebay but that one I listed is pretyy good its rare to find one of them being sold by a person on ebay, usually all "buy it now" |
British Colu...
Post Number: 415 Registered: Jun-05
| Posted on Thursday, June 29, 2006 - 04:36 pm: |
250001870084 thats without a bass remote and the one i listed above includes it (sorry not posting links it doesn't seem to show up on my computer, just copy and paste those item numbers into the search bar) |
Post Number: 35 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 05:35 pm: |
yea np, thanks for your help. It's no biggie to me link or not, just appriciate the help. If I was to buy one without a remote would it be to big of a deal, or can I do without one? Also about how much are they, i seem to see them about 40$, is this correct? Thanks again. |
British Colu...
Post Number: 418 Registered: Jun-05
| Posted on Thursday, June 29, 2006 - 07:05 pm: |
If you feel you need the remote then by all means get it, but I dont think its really that important you'll probably do more harm than good with it but if you want it then its best to get that 1st one i posted (you save a couple bucks bundling them together) and if you dont heres the item # for the remote if you want one later: 270001870523 Good luck with it and hope it works out nicely post pics when your done, also what car are you putting these into ? |
Post Number: 36 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 10:22 pm: |
It is a 97 Blazer, I bought it used but the guy left all the cords in, I belive they are RF. |
Post Number: 37 Registered: Jun-06
| Posted on Thursday, June 29, 2006 - 10:25 pm: |
And I'll post pics as soon as everything is finished. Haven't even gotten the subs yet prolly sum time next week, i guess thats what i get for going with indoaudio on ebay... ;) |
British Colu...
Post Number: 419 Registered: Jun-05
| Posted on Thursday, June 29, 2006 - 11:25 pm: |
Nice, I actually have a 97' Jimmy, even the smallest subs sound loud in these trucks, you wont be dissapointed. Yea I don't reccommend indoaudio, I hear of many horror stories from them. |
Post Number: 38 Registered: Jun-06
| Posted on Friday, June 30, 2006 - 08:47 am: |
Yea so far its a great 1st car. I was trying to decide Blazer or jimmy but then a guy was selling one down the street for only 1700 so i jumped all over it. Im going to be going out of town for the weekend but if you guys could keep givong me some advice it would be great. |
Post Number: 41 Registered: Jun-06
| Posted on Wednesday, July 05, 2006 - 02:44 pm: |
Ok I got a lil game to settle this. since im realy stumped. OK best amp out of these to push 2 12" Rockford stage 1 subs. Audiobahn a8000t or PG xenon 400.1 Both seem decent and about the same price. So i guess i will just go with what more people is better. First to 5 votes wins! Thanks for your help. |
Bronze Member Username: Mrmoneymachine8
Post Number: 18 Registered: Apr-05
| Posted on Wednesday, July 05, 2006 - 04:57 pm: |
the audiobahn one does 800 @ 2 ohms. im thinking of buying it for my solobaric 12 L7 |
