Thread: Mmats d3000.1 |
Bronze Member Username: Kravenblood
Ohio
Post Number: 64 Registered: Aug-05
| Posted on Tuesday, June 27, 2006 - 09:40 am: |
what you think about this amp? do you know of any other amp rated at 2700 Wrms @ 1 ohm with a samll footprint like this one DIMENSIONS ( L x W x H ) 13.375 x 11.5 x 2.125 and has anyone vere ordered from lightav.com |
Silver Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 890 Registered: Dec-05
| Posted on Tuesday, June 27, 2006 - 09:52 am: |
the amp is awesome, DK about the site |
Gold Member Username: Rovin
Trinidad & T...
Post Number: 8256 Registered: Jul-05
| Posted on Tuesday, June 27, 2006 - 11:20 am: |
never owned 1 but i know they r gr8 amps that r underrated & put out more than advertised , i cant remember seeing any other company that makes their amps small/compact 4 such a power package - i too am wondering how they do it ....... |
Ohio
Post Number: 67 Registered: Aug-05
| Posted on Tuesday, June 27, 2006 - 11:28 am: |
well i could of swore lightav said there 700 bucks i might pick one up if they are..anyone seen em at any other sites? |
Bronze Member Username: Nikoncd
Post Number: 62 Registered: Jul-05
| Posted on Tuesday, June 27, 2006 - 03:24 pm: |
www.woofersetc.com http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=384 Although they are sellin for $899, good luck though, them look sweet |
Ohio
Post Number: 68 Registered: Aug-05
| Posted on Monday, July 03, 2006 - 12:10 pm: |
well lightave gave em 900 for this years model s3500.1 but the site seems kinda questionable so i dont know what im doing yet |
Trinidad & T...
Post Number: 8322 Registered: Jul-05
| Posted on Monday, July 03, 2006 - 02:03 pm: |
what subs/system r u planning anyhow ?...... |
Ohio
Post Number: 69 Registered: Aug-05
| Posted on Monday, July 03, 2006 - 08:03 pm: |
stroker pro 15 in a 3 cube ported box tuned to 36 hz Factory specs...or just my stroker 15 in a 5 cube box tuned to 32 or 36 hz..havent decided yet, tang bang 61/2 in door tang bang 6*9 in back ran off deck and some brand of 5 1/2 in the kick panels ran off mmats sq2150... back of a 95 mitsubishi eclipse gs |
Gold Member Username: Juliob
Post Number: 1057 Registered: Dec-05
| Posted on Monday, July 03, 2006 - 09:10 pm: |
that's loud, post pics when you get it. |
Ohio
Post Number: 72 Registered: Aug-05
| Posted on Tuesday, July 04, 2006 - 08:58 am: |
scratch the tang bangs rms to high for deck |
