Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > Best amp/amps for 2 Alpine Type R's
Author Thread: Best amp/amps for 2 Alpine Type R's
Username: Randomxunknown
I have two Alpine Type R's, and i have no idea what size amp i should go with, i was looking @ two mono block 1000 watt alpine's but i dont know. the specs on those subs are 1,500 watts max, 750 rms, normal power rating of 500 watts
Username: Ctmike
Ct.
Post Number: 897
if you want 2 amps get 2 that put out 550-650w each.
alright, then how should i wire them? right now hey are wired to 8 ohms. im thinking im going to use these amps, the kenwood KAC-9102D
Username: Ctmike
Ct.
Post Number: 899
i wouldn't get a kenwood mono, unless thats all you can afford. what's the vc on the r's?
dual 4 ohms
they are dual 4 ohm coils
Username: Ctmike
Ct.
Post Number: 900
wire them to 2ohm load, if using 2 amps.
alright thanks.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 884
just get one amp that puts out 1000-1200w at 1 ohm
Username: Justblaze
St.Louis, MO
Post Number: 29
yeah, what julio said, youll get more output from your amp and more power to your subs if you wire both subs together for a 1 ohm load.
Post Number: 7
one problem, u cant wire 4 ohm dvc subs to 1 ohm, either way i have a single amp running both subs @ 2 ohms, its a el-cheapo LEGACY LA1868 2000 Watt amp. and it bumps them pretty nice for now.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1045
get hifonics 1206d, wire both subs in parallel to the amp, 1 ohm load.
Post Number: 8
i wont wire them in parallel mode, no way, no two subs are the same, thats why. ill run them the way i have it, its not hurting them nor pushing the, so its just right.
Username: Tjmutlow
Post Number: 2525
it does not matter which wya you run them series/parallel (bridged) or each speaker series and 1 speaker per channel, the power is the same.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1050
www.the12volt.com go and hit the link woofer wiring
Username: Dustin3
Tigard, Or
U.S.
Post Number: 1939
yup^^. i would also look at a kicker kx1200.1 wired to one ohm.
or if you are lookin at two amps get 2 zx750.1's and wire each sub to 2 ohms
or you could get a hifonics:
http://cgi.ebay.com/HIFONICS-BXi1606D-1600W-MONOBLOCK-Class-D-Amp-NEW-06_W0QQite mZ140002533432QQihZ004QQcategoryZ18797QQrdZ1QQcmdZViewItem
or 2 audiobahn a8000t's
"right now hey are wired to 8 ohms."
your also runnin ur subs at 8 ohms. dam. what amp do you have that can wire to 8 ohms and put out the power??? also 2 4ohm subs wire to a 1 or 4 ohm load FYI one 4 ohm sub wires to a 2 or 8 ohm load.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1058
bassman, a lil question, why did you recommend the 1606d, it puts out 1480w rms, i don't think type rs can handle that. The 1206 should be putting 1000w rms at 1 ohm don't you think. Their new stuff is like 75-80% lol!
Username: Dustin3
Tigard, Or
U.S.
Post Number: 1967
lol. yup their new stuff is.
each sub is rated at 750 rms (wut he said they are)... thats why lol
i'm just goin but wut specs he listed
Username: Dustin3
Tigard, Or
U.S.
Post Number: 1968
i'm assuming he has the 15" since thats rated at 750 rms
Username: Dustin3
Tigard, Or
U.S.
Post Number: 1969
he never stated wut size
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1060
lol yea he stated, 750 rms and 500 nominal power handling, jeje.
Username: Dustin3
Tigard, Or
U.S.
Post Number: 1976
lol. 750 rms. there ya go
Post Number: 10
nope i have 12's, lol, and im going to look into those amps that u sugested.
Username: Ctmike
Ct.
Post Number: 938
i wouldn't put a kicker 750.1 on each r if i was you. i've seen many sheets for those amps and the normally say they put out a little over 900w, which is a lot for a r. i wouldn't really go over 700w.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 1075
get hifonics 1206d
Username: Dustin3
Tigard, Or
U.S.
Post Number: 2003
^^^ or a kicker kx1200.1
Home > Message Board > Car Audio > Amplifiers > Archive through July 06, 2006 > Best amp/amps for 2 Alpine Type R's [ « Previous ] [ Next » ]
